shift knob removal??
Old 31 Dec 2005, 08:51 pm
Default shift knob removal??
my girlfriend has an '03 5 speed (with the factory 8-ball that she does not like) and i am trying to get that thing off. i have read many threads about using a wrench and banging it off.. but i spent about a half hour banging it with a hammer as hard as i can and it isnt budging..
any suggestions before i get the power tools out and cut/saw/drill it off?
Old 01 Jan 2006, 05:33 am
The stock shift knob on the GT is not threaded or glued. It has a "D-ring and clip" configeration. It can be removed in just a few minutes--wrap the knob in a towel, place a cresent wrench under the ball, tap firmly but gently with a hammer on the wrench which forces the knob upwards--the knob should "pop off" without damage to it or the shifter rod.
Old 01 Jan 2006, 12:13 pm
"banging it with a hammer as hard as i can "
be carefull you dont want to bend the shifter handle !!
Old 01 Jan 2006, 01:40 pm
Like Gary said, it takes a few minutes and the proper force to do. I was able to remove my knob just by pulling up on it and giving a slight twisting movement from side to side and it popped right off. Be patient with it, it's also best to do it in warmer weather, as the plastic ball is a little more pliable and moveable.
Old 01 Jan 2006, 03:36 pm
thanks for responses.. its not the GT though, and i think it must be glued on. i've tried just pulling with all the strength i could muster. the hammer/wrench method was going nowhere. i think i'm gonna give it a try with a heat gun. if that doesnt work i will go to the drill or grinder and get really messy with it
Old 05 Jan 2006, 01:19 am
I got mine off by tapping it (to get it's attention) and then using a strap whench and a couple karati yells and a jerk it came right off.[8)]
Old 07 Jan 2006, 08:30 am
It's not a GT and it has an 8 ball shifter on it? I have a ball shifter... well had one on mine (put it on myself). Maybe the dealer where she got hers at installed one. Check the front/back for a small screw that you'd have to use an allen wrench on to loosen. If it's on tight, banging with a hammer won't do any good.
You might have too look really carefully since it might be hidden just under the ball of it on a ring that wraps around the stick.
I have had about 2 aftermarket shifters, both had a ring under the ball and both used allen wrenches to tighten it up. It's a hard place to spot if you don't get down in there and look.
2001 Ltd Ed. Inferno Red PT, many mods, many more to come.
Old 08 Jan 2006, 04:05 pm
the heat gun did the trick.. still took a while to get it hot enough, then used the wrench/hammer to bang it off. it was the epoxy/glue that gave me the trouble.. no screws or spring clips there.
Old 09 Jan 2006, 03:38 pm
Definitely not factory... just somebodys 'cool' mod.
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
Old 11 Jan 2006, 07:17 pm
hey cheechz, what are you putting on the shifter ??
Error Codes skylight Tech & Performance Forum 6 07 Apr 2007 02:19 pm
2006 Cruiser Shift Knob Removal Mdanbury General PT Cruiser Discussions 2 04 Oct 2006 10:56 pm
Removal of gear shift knob on the turbo/Autostick amx1397 Exterior & Interior Styling 5 17 Nov 2003 09:27 pm
  Wordpress Themes | Submit article | Deaf Topics | Find jobs | Debt Consolidation
