Custom mount Double din possible??
Old 26 Mar 2006, 02:30 am
Send a message via AIM to douknowme12321
Default Custom mount Double din possible??
Does anyone know how much space there is behind the center console bezel? Im planning on seeing if there is some way I can secure a double din radio where the stock radio is. I have a 2005 stock radio right now, Now I have seen pictures where people have relocated the switch panel right below the stock radio to the empty pocket right below where it is now. Now i have taken off my center console bezel and saw that the switch panel underneath looks to be a separate box. Does anyone have any experience with this box and how deep it is? im guessing anyone who has replaced their stock radio is able to see how deep the switch box is? If it is about the same depth as the stock radio I dont think there would be any problem, Just have to figure out a way to securely mount it behind there. If anyone can help me with this first i will be able to try and think out the process a little further. Thanks guys and I appreciate and response I get..
**EDIT**
Sorry also wanted to ask if it is ok for me to remove the stock radio to get a better look behind there and replace without a problem? I remember my old car needed a code from the dealer and i dont want to go through that right about now. Will I be okay removing it, and putting it right back even if i disconnect it to mesure a bit? Thanks again guys
Tito
Old 26 Mar 2006, 04:39 am
Not my actual picture, jus borrowed it. But this is what I'm basically looking to do, crappy photoshop but sumthin i thru together in like 5 mins? do u guys think there is enough room behind there? I need about 7 inches of clearance since the unit itself is 6.5 inches deep.. Has anyone ever tried anythin like this? what would be the easiest and best way to securely mount it behind the trim? thanks again guys.. see ya
Old 26 Mar 2006, 04:10 pm
Striker's Avatar
In theory, everything is possible...look at the manual sketch:
If you remove the center and replace the other switchs elsewhere,it's maybe possible...
The you can smooth the whole thing (The pic it's only with a single radio for example)
Hope it helps
Old 26 Mar 2006, 10:40 pm
hey striker thanks for the info but what did u use to smooth it over??
Old 27 Mar 2006, 03:22 pm
Striker's Avatar
Body filler or polyester to integrate the elements. (I find this image on the web)
Custom Cruiser For Sale Wally Classifieds: For Sale/Trade 0 21 Jan 2006 11:23 am
2001 custom limited cruiser for sale GR8FLPT Classifieds: For Sale/Trade 1 09 Sep 2004 06:10 pm
Custom Neon Lighting~Group Buy! neonman Vendors & Buyers Forum 10 16 Apr 2004 11:47 pm
F/S:Motor Mount Inserts JSTANEON Classifieds: For Sale/Trade 1 11 Mar 2004 10:26 am
Custom Cruiser Calendar Contest skylight PT Cruiser News and Rumors 12 17 Nov 2003 12:12 am
