I've had a recurring problem with the car not coming out of Park. My driveway is not very steep, but nonetheless I got stuck a month or so ago. The tow truck came out, and lifted up the rear end, I say wait a second. I jumped in and was able to get it out of park.
Now today it happened again and I'll have to have it towed to the shop. Anyone else have this issue? I'm at 45K miles and dealer won't cover it under warranty. What I WANT to do, is disconnect that feature. short cuts? Steve PS-since that last time it happened, I have been putting it in Neutral, setting parking brake, releasing pressure, and then putting it into park. |
not sure about disconnecting it... you mean the 'feature' that won't let you take out the key unless the tranny is in Park?
Looks like the problem is your driveway has just enough slope to put a load on the 'park' gear, and you can't pull it out because of the pressure. Easy but expensive answer: have it towed to your dealer; attach a blank check, and figure your kids probably won't miss the semester or two of college. Sleazy trick: when parking: in Neutral : set parking brake. make sure the car won't roll. then shut off engine. (one click counter-clockwise... engine off) Then put it in park and remove key. Maybe having the engine running and passing thru R on the way to P 'preloads' the drivetrain, putting extra stress on the parking pawl. Or maybe back in? Have the other end of the car facing downhill? Just tossing some Ideas... --Check Engine and Transmission mounts?
I just tell anyone who asks that "PT" stands for "Plymouth's Tombstone" --- Defend Our Hobby! Join the SEMA Action Network http://www.semasan.com |
The problem is the slope. My understanding is that park is like a pin that slides in, and on a slope, the weight of the car pushes that pin against side of hole it's in, making pulling the pin out very hard to do.
I bet you don't have the problem in a level parking lot, do you? Sorry, don't have a cure, except to try to find more level parking places.
with the emergency brake pulled way up then put the car in park do you still have the problem ?? [:I]
This time even that didn't work. This morning (6:30am 30 degrees) I jacked up the rear end two feet on jack stands to make the car level. Still won't come out of park. Going to have to tow it in I guess. I'm just out of warranty and dealer says it could be $600-$700. I HATE THIS FEATURE!!!!!!! I'm gonna pull the knob off tonight in the very slight chance there is something I can do in there. If I knew where that pin was, I'd cut it. [xx(] |
wow that stinks !! keep us posted !!
| Error Codes | skylight | Tech & Performance Forum | 7 | 28 Apr 2011 03:34 pm |
| Error Codes | thegoldpt | Turbo Performance | 6 | 07 Apr 2007 02:26 pm |
| Error Code List | skylight | General Turbo Discussions | 6 | 07 Apr 2007 02:11 pm |
| to lock or not to lock | dcartwright | PT Cruiser Convertible Forum | 0 | 01 Jul 2005 03:27 pm |
| Auto Tranny will shift even if in 1st gear? | BumperBob | Tech & Performance Forum | 4 | 07 Apr 2005 11:07 am |
