Overhead Console
Old 17 Mar 2007, 08:28 pm
Default Overhead Console
I just bought a 2001 Cruiser. The question I have is about the overhead console (compass and temp). It does not work (just dead). The previous owner said it went out a while back. I have checked the manual about the possibility of it being a fuse and see nothing. Could this be a bulb or maybe a fuse in the unit? Or do I have to replace the whole unit? I do not want to get into it without knowing more about this. Thanks....Bruce
Old 18 Mar 2007, 05:56 pm
Not sure what the problem is but if you have to replace it, check with e-bay first. I bought one there a couple of years ago a lot cheaper than what the dealer wants for one.
Old 19 Mar 2007, 02:17 pm
Check fuse 18 (15 amp) in the PDC (underhood), and Fuse 14 (20 amp) in the fuse block (left side of dash). Ground is located in rear center of dash, but unless someone has messed around there, I doubt that's the problem.
If the fuses are okay, you could pull the console to check power and ground at the unit, but at that point it may be the whole thing. Good Luck.
Old 22 Mar 2007, 09:16 am
Thanks to both of you for the replies. I will check the fuses.
Old 31 Mar 2007, 02:19 pm
nope not the fuses...
Overhead console cutout template needed. hal_armour General PT Cruiser Discussions 11 29 Sep 2008 10:53 am
Overhead console gonzomania Interior Accessories Forum 7 16 Jul 2005 12:10 pm
Wiring to overhead console ptblue02 General PT Cruiser Discussions 3 06 Jun 2005 01:32 pm
REQ: Images of Overhead Console Unit Installed neps Interior Accessories Forum 0 22 Jun 2004 06:42 pm
Overhead Console Rattle scatman General PT Cruiser Discussions 1 07 Nov 2002 11:17 pm
