Battery powered Outlet port
  #11 (permalink)
Old 07 Jul 2007, 05:20 pm
soonercruiser's Avatar
Wink Re: Battery powered Outlet port
Just think of it this way...the charger can convert the voltage...but will only be converting and using significant energy IF SOMETHING IS PLUGGED INTO IT TO "DRAW" ENERGY THROUGH IT!
  #12 (permalink)
Old 07 Jul 2007, 06:43 pm
BeachBum's Avatar
Default Re: Battery powered Outlet port
Originally Posted by CREWZIN View Post
BeachBum,
I'll agree about the extension cord, but I thought that maybe with the phone charger that converts the 12 volts to whatever the phone uses, it might draw something. I had to prove it to myself so I just hooked up my PT battery to a meter (a steady 12.08 DC volts ) and then pluged my cell phone charger into the live socket. The charger even has a small red light to tell you when it's pugged in and there was NO change in the reading of the meter. NO draw n the battery at all.
Cool. Always good to have experience-backed science! I thought after I posted that there may be a small change for an unmeasurable "leak" of power as it was be converted, but since he tested it, all is good. Thanks!
2007 P/T Cruiser
Bright Silver Metallic - Pics in my gallery up there ^
Just started modding.
In a continual state of cruising.
  #13 (permalink)
Old 08 Jul 2007, 03:44 pm
PlumCrazyMonkey's Avatar
My son leaves his phone charger plugged in all the time in his 90 Dodge Spirit ES and has never had to call dear old dad for a jump. I come home at night and there is always a red light on from his charger, so I guess you can use that as a sworn testimony..lol.
Clay
05 PT Non Turbo Dark Plum, Crane Firewires, Bosch Platinum 4's and K&N Drop in.
72 Plymouth Satellite Sebring Plus, Street/Strip.
64 Chrysler New Yorker, 54K original Highway
  #14 (permalink)
Old 08 Jul 2007, 10:10 pm
Post Re: Battery powered Outlet port
I have an 06 GT and it does have an outlet in the bottom part of the console and I plug in my cell and it draws very little when I only have my converter pluged in I can't see any dishcharge. Oh yes the outlet is hot at all times.
  #15 (permalink)
Old 09 Jul 2007, 01:28 am
Originally Posted by BeachBum View Post
It's the same concept in your home. If you plug in an extension cord but don't plug anything in the cord, no power is being used. Energy can't free-flow from the outlet. It's only putting a slight drain on the battery when it's transferring a charge into a phone.
Well not quite, anything that is a charger will have a slight draw on it, such as say a dc convertor for a walkman etc. I was actually quite surprised that this was mentioned yesterday during the "Answer the Call" parts during the huge Concert for the Environment yesterday.
Regards
Terry
  #16 (permalink)
Old 10 Jul 2007, 09:43 pm
Check out your fuse box and owners manual. On my 06 turbo lite I can put the fuse in two different ways - always one, or on with ignition!
  #17 (permalink)
Old 12 Jul 2007, 12:19 pm
I leave my phone charger plugged into my console plug all the time. I have had it plugged in for about 10 months now and have yet to have a problem.
  #18 (permalink)
Old 12 Jul 2007, 08:24 pm
Yes, but if you left it plugged in for ten months without starting the car, it would possibly drain the battery. There is no big draw from the cell phone on it, but it does take some current to keep the little light on it lit. That's all that I was saying.
Regards
Terry
PT Crusier battery dies after 5 days of no use. PT OWNER General Turbo Discussions 22 28 Jan 2009 11:51 am
Battery change turbomangt General Turbo Discussions 18 24 Jun 2008 02:58 pm
Possible Battery Problem ? Johns Steel Blue Tech & Performance Forum 2 02 Jul 2007 08:31 am
Battery Corrosion SteelBlueGT General Turbo Discussions 9 19 May 2005 06:47 pm
Volume reduced when battery disconnected tom-t-rifik Sound and Security Forum 0 28 Jun 2004 05:25 pm
