USB ports for power only?
Old 06 Jul 2007, 06:33 pm
jimmirehman's Avatar
Default USB ports for power only?
If i buy one of those PCI slot USB port things for computers (the ones that have a cable that runs from the motherboard) can i some how piggyback them off of something in my PT cruiser to simply provide power? I would rather install USB ports in my cruiser for chargeing devices rather than buying a bunch of stupid coiled car chargers for everything. any advice? I was thinking in that aera of the 07 cruiser's middle section where the hazard light button is. any thoughts instructions etc?
Old 06 Jul 2007, 06:46 pm
Default Re: USB ports for power only?
for instance, i wanna take somethin like this and mount it into the cubby in the center dash and somehow have it draw power from the power outlet's power
Old 09 Jul 2007, 11:49 pm
No need to use a pci card. Get one of those cheap usb hubs ($18) and a car usb adapter($15). Wire it right in. Either mount in the dash if you want to cut or double sided tape under.
2005 PT Cruiser GT
Old 10 Jul 2007, 10:36 am
zapwizard's Avatar
giantrobot has it right, either a external USB hub, or a internal drive-slot model as you have shown an image of will work. (They are the same electronics, different form factors)
The catch is that those need +5volts to work, and your car is 12 to 13.5volts.
So you need a 5-volt car adapter to run the hub. You can buy a RadioShack 5volt adapter that can put out about 1amp which is about what you need if you are charging 4 devices. I have taken them apart before and hardwired them into the car, rather then plug them into power outlet.
Old 10 Jul 2007, 03:09 pm
This 5 Volt adapter at radio shack, it is a cigarette styled plug? can i some how use the unused molex connector (for another power outlet) found in the passenger window controls section to gain power to a USB hub then cut a whole in the center console and mount the USB hub that way?
Old 12 Jul 2007, 07:43 pm
I would just splice into one of the existing accessory lines. Cutting the dash could go good or bad. I would recommend having it done professionally.
2005 PT Cruiser GT
Old 13 Jul 2007, 10:02 am
Before you start feeding an unregulated 5 v 1 amp current into those Little Bitty rechargeable batteries...
You might want to install one of these:
DataSheet_AutoFX
Best bet is to start with a car usb charger , then feed the hub.
Defend Our Hobby!
Join the SEMA Action Network
http://www.semasan.com
Old 13 Jul 2007, 11:10 am
DataSheet_AutoFX
? Wasn't that what we were talking about? maybe I'm confused.
2005 PT Cruiser GT
