PT Cruiser Forum Car Videos
Car Rims
general cabin filter question and installation tip
  #11 (permalink)
Old 17 Feb 2008, 03:52 pm
littleblueGT littleblueGT is offline
Default Re: general cabin filter question and installation tip
I ordered 2 cabin air filter systems from Wyckoff Chrysler for my wifes 07 n/a, and my 03GT. I was a little upset that they didn't have the mesh cover. The wifes 07 had the filter housing and the mesh cover already, and my GT only had the shroud and no filter housing. I found that Mcmaster-Carr had a carbon filter that can be cut in half to make 2 filters @ $6.73 each. I will use the carbon filter for the next change. Before I had the filter housing I placed an aluminum screen over the square frame and placed a thin foam filter sheet over the mesh, and secured with tie wraps. That worked great for several months at a time and was totally black when I changed it.The fiber glass filter in front and the carbon filter behind should take care of most air polution. The filters are used normally in a hobby spray booth and are 6 inches wide and 18 inches long.
  #12 (permalink)
Old 17 Feb 2008, 07:18 pm
outfit's Avatar
outfit outfit is offline
Send a message via Yahoo to outfit Send a message via Skype™ to outfit
okay i have an 06 were is the incabin filter located ???
Just bought 06 PT Cruiser Touring ,So it is a Work n Progress .....,It has Xenon Blue headlights, Xenon Blue Turn Signals, Xenon Blue Back Up Lights, M3 Smoke Mirror Lens Blue Leds.. Pioneer DEH-P7800MP with Sirius Sat Radio Tunner ( SIR- PNR1 ),Rockford Fosgate Power 6.5 ( T162C)front door Rockford Fosgate 3.5 ( P132C) Limo Tint , Synthetic Oil, Bosch Platinum +2, FireWire Crane Cams 8.5.. ,,,,2 Car Seats....
  #13 (permalink)
Old 17 Feb 2008, 08:33 pm
The filter housing is behind the winshield washer reservoir under the black plastic cowl (passenger side). Do a search as there is an instruction on how to install the filter housing.
  #14 (permalink)
Old 04 Apr 2008, 08:32 am
tfakehany tfakehany is offline
Talking Re: general cabin filter question and installation tip
HINT;
I found that the plastic screwlike pins holding the top of the grill can be reached from the underneath side of the metal in the engine compartment and that by squeezing the assembly from underneath while unscrewing worked the easiest. The side screw because of its location came out the easiest.
anyway, i recommend installing a cabin filter. it's pretty easy to do and it does make a big difference. to save some money, you may want to remove the cowl cover and take a peak to see if you need the filter housing or just a filter. tip: the cowl cover screws are not really screws. they are more like push pins. they need to be gently pried/"walked" out with a thin flat blade screwdriver. [/quote]
  #15 (permalink)
Old 04 Apr 2008, 06:49 pm
CruisinDad CruisinDad is offline
There is a bit of a thread on this topic in the "General Discussion" forum. Worth a bit of an extra read. Here's the link.
Cabin air filter
  #16 (permalink)
Old 14 Apr 2008, 09:02 am
arkansascarnut arkansascarnut is offline
I would like to know as well if there is a filter or screen of some sort that I need to be cleaning inside the car to prevent dog hair, etc from clogging the evaporator. I purchased the car used and it's taken five months to remove all the random dog hair embedded into the carpets.
Tim the ToolMan
Little Rock, AR
My babies are my dogs and my cars...4 of each
2005 PT Cruiser Convertible
2003 MBenz S500
1998 MBenz SL500
1997 MBenz E420
  #17 (permalink)
Old 14 Apr 2008, 09:18 am
Unhappy Re: general cabin filter question and installation tip
From what I have read and observed there is only a place to install a filter on the air coming into "the car" and not a place to put a filter on the re-circulating air within the vehicle to catch animal hair. Sorry but it seems that animal hair is a problem solved by others in their later vehicles.
  #18 (permalink)
Old 28 Jun 2008, 03:55 pm
DJmart's Avatar
DJmart DJmart is offline
Send a message via AIM to DJmart
Old post, here I go again.
I have the 2001 cruiser limited and today I just changed my moms 2004 civic hybrid cabin air filter.
I was curious to know if I can drop-in a filter for my car, without hacking and cutting or what ever to make it fit.
No problem on buying the filter, I get a discount at Napa Auto Parts anyway.
Let me know!
Thanks fellas.
  #19 (permalink)
Old 28 Jun 2008, 04:09 pm
CREWZIN CREWZIN is offline
If you get the filter, there's no problem just dropping it in, but a little hassle to get at it. It's on the passenger side and you get at it from the engine compartment. You have to take off the dark gray piece that's right in front of the windshield and around the washer fluid refill cap plus anything else that's in the way. The PT didn't come with any filter so you won't be replacing one, you'll be adding one. Good Luck.
  #20 (permalink)
Old 28 Jun 2008, 07:45 pm
Ironman Ironman is offline
Does anybody know if the filters and kits are interchangeable from year to year?
vB code is On
Compare/contrast Air Filter Elements andym Tech & Performance Forum 7 02 Jul 2004 11:02 am
  Debt Management | Adult ADHD | Mortgage | JJ Benitez | Loans
