Center Console Removal
Old 26 Jan 2002, 10:27 pm
Default Center Console Removal
How in tarnations do you get that doggone console off?! That dagnam e-brake gets in the way!!!
Old 26 Jan 2002, 11:27 pm
It isn't easy . I sit between the seats with the handle between my legs and with both hands , pull it up as far as I can , then recline both front seats , move the shift lever as needed and mine came out ok . Guess if your brake adjustment is tight , maybe you won't be able to get the handle up far enough . Good luck .
Old 26 Jan 2002, 11:38 pm
YIKES!!!!!!!!!!!!!!!
Old 27 Jan 2002, 12:40 pm
UH-HUH
Old 30 Jan 2002, 06:41 am
<img src=icon_smile_evil.gif border=0 align=middle>Im having the exact same problem!!!!!<img src=icon_smile_blackeye.gif border=0 align=middle>
2001 Touring, rear splash guards,
smoked back up lights, red turn signals, adjustable antenna,LED washers, pedal covers
Old 30 Jan 2002, 02:20 pm
Might sound like a stupid question..but was just woundering why you guys are taking the console out to begin with?
Old 30 Jan 2002, 08:50 pm
I took the center console out to install a Hurst shifter and also to paint it to match the dash. To remove the console,pull back on the e-brake as far as possible,undo the four screws,and unscrew the lumbar handle if your car is so equipped. Next put the seats in the reclined position and move them all the way back.Lift the console enough to get your hand under it and undo the socket plug and the window switches.Pull up on the rear of the console pressing in on the back ends a little and push forward and upward clearing the e-brake.
To put it back in just go reverse,its just as fun. Good Luck.
Old 30 Jan 2002, 09:49 pm
I wanted to wire in a flameball to the automatic trans. indicator light and remove the shift bezel to paint it .
Old 31 Jan 2002, 03:27 pm
Ahhhh..now I understand..hey, Inferno Cruiser..how's that Hurst shifter work for you? Does it give you the nice, tight, short throws of Hurst shifters of the past? I've always loved the feel of those .
Old 31 Jan 2002, 07:23 pm
The Hurst shifter is a big improvement over the stock shifter. It gives you tighter and shorter throws.It was well worth the money and time it took ot install,about an hour and half. I bought it from Moss Motors,$199.00.It was the best price I could find and Moss Motors is great to deal with.
Center console flood light toneman Interior Accessories Forum 2 28 Feb 2006 07:34 pm
Removing Lower Center Console CHROMEDCRUISER Interior Accessories Forum 3 03 Jan 2005 10:27 am
Body Colored Center Dash Console patbluecruiser Interior Accessories Forum 20 05 Jun 2004 08:27 am
Modify the Center Console for 1 1/2 DIN Stereo erwinlg Sound and Security Forum 0 12 Dec 2003 02:56 pm
center console lchiwahs Interior Accessories Forum 19 02 Nov 2003 11:26 pm
