Dome light removal
  #11 (permalink)
Old 30 Jul 2008, 09:23 pm
Send a message via AIM to CYCLONE_06 Send a message via Yahoo to CYCLONE_06
Default Re: Dome light removal
I tried putting LEDs in my dads dakota SLT. For some reason, the lights stay on all the time with a really low glow. Now, I have the same bulbs in my R/T, which is a sport model, and they go out completely. The only difference is, my dads truck has a fade circuit, where the lights fade out slowly. The PT has the same thing... so wouldnt the LEDs stay on still ?
I was gonna convert my bulbs over to LEDs in orange, since I have the dream cruiser, but if they are going to stay on, then I was just gonna buy the glass bulbs in orange.
~CYCLONE_06
  #12 (permalink)
Old 30 Jul 2008, 11:18 pm
PTmodrod's Avatar
Well i am pretty sure that the LEDs and the incandescents will behave the same. the only reason i can think that they would stay on is if there was a small trickle of power running through it, but even then the filament of the incandescent bulb would glow slightly... Another user on this forum uses them and they seem to work fine though.
01, Inferno Red, PT LE, 5-speed Manual.
EXT:American Racing Casino wheels, Intrax Lowering Springs, California Cruisers Shark front and rear rollpan, red lighting
INT:Hurst Short Throw Shifter, Factory 8in rear sub, red footwell lighting, In-dash radar detector, Starter button, custom switches
PERF:OBX Tube Header, ECC High Flow Cat, Borla Dual Cat-back Exhaust, Drilled and slotted rotors and performance pads
Custom Decals From Metro Car Design
Pictures of my PT
http://www.banfielddesign.com
  #13 (permalink)
Old 31 Jul 2008, 03:55 pm
Yea I ordered a set of festoon orange LEDs for the front, and a 921 matrix for the center / rear dome. I also got a chrome amber 921 glass bulb for the rear cargo area. Hopefully they will all work correctly, and go out without glowing.
The only thing I could figure is that the truck has a current going through it like you said, and LEDs run on lower voltage, so it picks it up and glows, but the incandescent glass bulb needs more energy to light up, so it doesnt glow.
~CYCLONE_06
  #14 (permalink)
Old 22 Aug 2008, 04:07 pm
outfit's Avatar
Send a message via Yahoo to outfit Send a message via Skype™ to outfit
okay here is a quick question... which is the replacement bulbs for the 2 dome lights? The front being TS 212-2 and the rear is TS - 578.. I went looking on superbrightleds, but not to sure which one will work. Can I get some help...
<---- Just installed.
2006 PT Cruiser Touring Non-Turbo
3 -Hyper White Thin Flexible 5mm LED Dome Lights from Oznium Damn they make a dif in the inside ,let me tell you the best led lights you can buy
1 -Hyper White 921 Superstar Bulbs from Autolumination
1 -Hyper White T10 Wedge 194 (Lic Pllate) Super White LED from Autolumination
Pioneer Head unit W/ HD & Satellite radio
2 - 7inch DVD/Headrests Monitors... dvd players built in the headrests
HID Lights 8000k 9006 for lows from xhidoutlet....
HID Slim 55w 6000K for high's from HIDGEEK.
  #15 (permalink)
Old 22 Aug 2008, 04:23 pm
DJmart's Avatar
Send a message via AIM to DJmart
Cross reference:
4410 = 212-2
579 = 912
pain in the butt isnt it? I had to do a lot of research first to find the right bulbs.
Enjoy.
  #16 (permalink)
Old 22 Aug 2008, 05:31 pm
outfit's Avatar
Thankx....
  #17 (permalink)
Old 22 Aug 2008, 05:32 pm
DJmart's Avatar
TAKE PICS WHEN DONE!!!
  #18 (permalink)
Old 22 Aug 2008, 06:18 pm
outfit's Avatar
okay found the 4410's for the front dome and the Lic plate one , but can't find the one for the rear dome the TS-579.- 921..did you use the festoon bulb type if so which one was it ??
  #19 (permalink)
Old 23 Aug 2008, 12:58 am
DJmart's Avatar
The rear dome light is tricky, it is not a festoon (tube) type bulb, its a wedge!
921!
consider wide angle LED's if they have them, and when you install them use some aluminum foil directly across from the beam the LED creates, it helps deflect the light!
  #20 (permalink)
Old 23 Aug 2008, 02:39 pm
outfit's Avatar
holy whacky bat wings.......... you said to use foil to direct the lights.. I was thinking about using 6 LED Feston Bulb and then trying the Luxart LED Module ....either way going to buy 2 and also experiment with the ALM - RB x 3 ...if I am not mistaken the 2 outside point at 45 degree angle..... Do you have any pics from yours
LUMINICS head light and fog light bulbs 03baggedturbo Vendors & Buyers Forum 8 22 May 2008 08:36 am
how to hook up a rear floor aux light pppt03turbo Exterior & Interior Styling 4 15 Dec 2005 09:57 am
DOME LIGHT turbomangt Exterior & Interior Styling 2 23 Dec 2004 02:57 pm
Removal dome light lens turbomangt Interior Accessories Forum 2 19 Oct 2004 04:17 pm
Colored dome light Kammler68 Interior Accessories Forum 0 23 Apr 2003 08:33 pm
