Center High Mounted Stop Light
Old 06 Jul 2008, 11:49 am
Default Center High Mounted Stop Light
Help! I went to change the bulbs in the center stop light and when I gave it a gentle tug they broke off. This happened to two of them. I left the third one in, afraid that would break too. The bulbs were scorched and brittle. Can someone tell me how do to get the rest of the broken pieces out?
Old 06 Jul 2008, 05:03 pm
Default Re: Center High Mounted Stop Light
Not sure why that happened but whenever I get a broken bulb like that I use a needle nose pliers to grab hold of whatever I can and turn it clockwise or just pull it out, whatever works.
Old 06 Jul 2008, 09:16 pm
just as crewzin said ,, if you se a spark you might blow a fuse though, so make sure the work before closing it up
Old 06 Jul 2008, 09:39 pm
soonercruiser's Avatar
Wink Re: Center High Mounted Stop Light
Worried about colateral damage from a spark if you grab both contacts?
Simply disconnect the battery first.
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Small light under center console? DJmart Tech & Performance Forum 3 30 Sep 2007 11:03 am
Center console flood light toneman Interior Accessories Forum 2 28 Feb 2006 07:34 pm
Turn signal & stop light gonzomania General PT Cruiser Discussions 12 25 Apr 2004 01:18 pm
