Inside Paint Job
Old 06 Aug 2009, 08:29 am
she_so's Avatar
Default Inside Paint Job
Hi
I've decided to take a time out from working on the outside of my car and go for the inside since there is only a couple of things I wanna do. First off I own a 2008 PT Touring Edition. I would like to paint my center console. I want it to match the outside of my car. Which is some color orange and silver. I have a tube and name of paint the shop used for my outside. But where do I go from there?
*Do I use spray paint or a brush?
*How do I get that Console off?
*Any designs floating around out there?
*Time?/Cost?
I want to try and get this done this weekend. It will be raining here in Virginia so I have to fill my day with something.
I've read a cuple of post all the way back to 2007. I couldn't find the detailed one that candyman posted but I know its out there because I've read it before. So if any one can help with those few questions I would appreciate it.
SHE SO
"Tampica"-2 Tone Paint; Chrome Pillar Posts & Mirror Caps; Scuff Guards; Custom Air Bag Graphic; Custom 3rd Brake Light
Old 18 Aug 2009, 04:32 am
Charon's Avatar
Smile Re: Inside Paint Job
G'day, SHE_SO,
If you do go down the paint option, you "MUST BE SURE TO",
Spend A LOT of time to make the console "very clean".
Use a Scourer pad,
Wipe all surfaces to be painted very well with Prepsol. (more than once)
Make sure you apply 1 or 2 light to medium coats of Plastic adhesion primer. ie. K&H (brand).
"THIS STEP IS A MUST DO"
Then just,
Base coat, Clear coat,
Add 1 extra clear coat, "protection"
Regards, Andrew...
PS If you need a workshop manual, You can download a copy from my File dump @ MobileMe - iDisk
Old 18 Aug 2009, 05:17 am
Candyman's Avatar
Hey their she_so,
Here is a write up I did a while back on this subject. It is probably a little over thorough but is a very complete explanation of how to pull off a professional looking paint job, and covers everything in detail so you should be able to pick up the basics, and see where you go from their. Just as Charon already said, prep is a huge part of pulling off good results! Here is the Link.
Guide to Spray Paint your Center Dash Bezel
Go easy, best of luck on your project if you go ahead with it. and also if you do, please post some pic's to show off your hard work!
Candyman
Check out my Custom PT Club Website: http://westvalleyforum.proboards.com/index.cgi
And my ever growing PT Photo Archives: http://s458.photobucket.com/albums/q...uiserArchives/
Got a Question? Drop me a line anytime: westvalleycruisers@yahoo.com
Old 18 Aug 2009, 02:50 pm
dsmturbo's Avatar
Default Re: Inside Paint Job
candy, just what I was looking for, thank you again Sir.
Now, just have to find out how to remove centre bezel without pooching it LOL.
I saw a how to here somewhere
2003 PT Cruiser GT, turbo, Inferno Red Pearl, autostick, 84K, MSD 8.5m wires, NGK iridiums
Old 18 Aug 2009, 08:07 pm
Candyman's Avatar
Hey their DSM Turbo,
No problemo, Sir! I am always more than happy to help out wherever I can. Here is how you remove the center bezel for paint just in case you didn't already find it.
1) Pop out all of your A/C control knobs.
2) You have to pry out the window switches. Grab a thin piece of cardboard or wood and slide it in the gap between the switches and the center bezel itself. (Bottom works best) Use a flathead screwdriver and GENTLY pry the switch out. (First time you do it, you'll be extremely hesitant.. after that, it's easy)
3) Disconnect the harness connected to the window switches.
4) Unscrew the bolt at the top center of the bezel that attaches it to the frame of your dash.
5) Lastly, you have to pry off the center bezel, applying the same practice as the window switches. I have found it's best to work from the bottom edges, up.
Originally posted by chris15...
Go easy, work slowly, and methodically, and as always, if you ever have any questions, please feel free to drop me a line anytime.
Candyman
Old 19 Aug 2009, 01:16 pm
dsmturbo's Avatar
Thanks to Chris15 and candy, take care
Guide to Spray Paint your Center Dash Bezel Candyman The Detail Shop 1 28 May 2009 07:30 am
Guide to Detailing: Buffing You Paint Candyman The Detail Shop 4 03 Aug 2008 04:08 pm
Guide to Detailing Your PT: Claying Your Paint Candyman The Detail Shop 1 01 Aug 2008 03:15 pm
Self cleaning paint turbomangt The Detail Shop 4 19 May 2004 08:18 am
Paint Chips turbomangt General PT Cruiser Discussions 1 08 Aug 2003 02:44 pm
