guage wiring help needed
Old 26 Sep 2003, 08:14 pm
Default guage wiring help needed
ok been out pre-wiring my guage pod, and dash, also ran the vacuum line into engine bay.
where is the dimmer wire to tap into? (got pics?)
where can I tap into inside the car for key-on power?
and finally for my volt guage, key-on power or power on all the time?
thanks punch
Old 26 Sep 2003, 11:32 pm
First of all I believe that there is an orange wire in the harness at the base of the pillar for the dimmer. For Key on power, on my gauges I used an Add a circuit fuse replacement which holds 2 fuses one for the fuse in the fuseblock that you are replacing, and one for the circuit that you are adding. The radio fuse is an ignition on source, and by using add a circuit you do not jeapordize the integrity of the radio power in any way (because it still has its own fuse) The volts gauge needs to be an ignition on source also. I'll see if I can get some pics of my fuse box with the add a circuits in it. I got them at pep boys they were something like $6.99 ea. I'll post a pic of where I have my boost gauge connected in. You need to be sure you get a port with vacum as well as boost.
Alan [}]
Old 27 Sep 2003, 01:22 am
I see where u have your boost tap.
Will where u tap alter your boost readings?
Homepage:
Old 27 Sep 2003, 05:19 pm
[quote]Originally posted by Gear_Head
thanks gearhead pics would be great, I like to do things just once.
Wiring guru needed turbomangt Sound and Security Forum 3 01 Aug 2005 08:52 pm
Amp wiring advice needed... Beacon Sound and Security Forum 2 23 Oct 2003 11:11 am
Nice find for guage wiring. "the orange wire" Punch Exterior & Interior Styling 4 03 Oct 2003 08:40 pm
guage wiring (again sorry) Punch Exterior & Interior Styling 2 26 Sep 2003 11:35 pm
Wiring Info Needed GTPT General Turbo Discussions 3 15 May 2003 11:01 pm
