help installing starter dash button
Old 31 Oct 2009, 11:08 pm
Default help installing starter dash button
help please....i want to instaLL A STARTER BUTTON ON DASH AS MY KEY DOesN'T SEEM TO WANT TO ActIVATE THE STARTER SOMETIMES.....BUT EVERY WHERE I LOOK OR CHECK IT SAYS I SHOULD USE YELLOW WIRE FROM HARNESS BUT I HAVE 2008 PT CRUISER AUTO MATIC NON TURBO AND I CAN'T F FIND THE YELLOW WIRE ANYWHERE I FOUND IGN MODULE BUT THERE WAS NO YELLOW WIRE COMING FROM THERE???.....DOES ANYONE HAVE A PIX OR LOCATION!!!...CAN I JUST GO OFF RELAY TO POWER NEW SWITCH?
Old 02 Nov 2009, 03:51 pm
Duster's Avatar
Default Re: help installing starter dash button
No more caps please.
Old 02 Nov 2009, 06:10 pm
sorry didn't know
Old 02 Nov 2009, 07:08 pm
Using CAPITALS is shouting on line. Everyone is holding their ears!!!
Old 02 Nov 2009, 09:04 pm
I am unsure if 2007 an 08 are the same , but....
This is for remote start-
PASSIVE ANTI-THEFT YES TRANSPONDER SEE NOTES
12 VOLTS Red Ignition switch harness +
IGNITION Pink/white Ignition switch harness +
ACCESSORY Violet/brown
Second IGN is ground through 600-omhs and Second START is ground through 180-ohms. Refer to the supplied diagram for exact wiring instructions.
STARTER Pink/blue
STARTER 2 Violet/brown
TACH SIGNAL Use a fuel injector
FUEL INJECTOR Opposite from Green/orange At any injector on engine AC
LOCK Lt.green/dk.green In driver's kickpanel mux
One wire doorlock system. 1-kohm to ground for lock and 250-ohms to ground for unlock.
UNLOCK Lt.green/dk.green In driver's kickpanel mux
DOORPIN SEE NOTES
Tan (driver's door), Tan/red (passenger door), Tan/orange (rear left) and Tan/yellow (rear right). All 4 wires are (-) and found on the back of the instrument cluster.
HOODPIN Brown/tan At pinswitch under hood -
TRUNK PIN Tan/black In driver's kickpanel -
TRUNK RELEASE Tan/green In DKP or behind instrument cluster -
FACTORY ARM Through OEM remote only
FACTORY DISARM Through OEM remote only
BRAKESWITCH Green/white At switch above brake pedal +
PARKLIGHTS White/violet Low in driver's kickpanel +
HAND BRAKE White/black At switch on handbrake lever or behing instrument cluster -
HORN Dk.green/violet At steering column
2003 PT .. Stock besides tint an audio.
Pioneer 8600
Suprisingly crisp stock mids/highs (for now).
2 - image dyamic ID 8's
1.8 cubes tuned 30hz
Old 04 Dec 2009, 05:41 pm
Same from me.
I am happy to recieve PMs but not if they are merely questions that can go on the forum.
So if you are going to pm me, you had better make it really personal..... ? ? ? ?
Stripped a thread while installing my starter RainyTX Tech & Performance Forum 1 08 Jan 2009 08:34 pm
start button..how do I do it? careyk General PT Cruiser Discussions 20 10 Jun 2008 11:26 pm
help installing in-dash dvd Kammler68 Sound and Security Forum 14 06 Feb 2006 07:57 pm
engine start button Musicman Exterior & Interior Styling 6 31 Dec 2004 12:24 am
UP AND DOWN BUTTON turbomangt Exterior & Interior Styling 4 08 Dec 2004 08:16 pm
