PT Dash vents not allowing air flow
Like Tree2Likes
Old 29 Nov 2010, 07:46 pm
Default PT Dash vents not allowing air flow
Hi, trying again... Both drivers side and passenger side dash 'face vents' of a 2005 PT Cruiser havenít allowed cold/hot air to be blown through for the past month. The a/c and heat work fine on the floor/feet vent, hot side is hot and cold side is cold. I checked the obvious that the vents weren't closed and tried moving the dash knob to dash face vent only or and it doesnít feel stuck or broken. All solutions (the cheaper the better) welcome, let me know if you have any other questions. thank you!
Old 29 Nov 2010, 08:48 pm
Default Re: PT Dash vents not allowing air flow
Sounds like the blend door isn't operating to allow air to the dash vents. First take off the center dash and see if the controls are actually moving when you turn the dial.
Then see if you can get under the dash to where the wires actually go and see if they are connected to the levers that open and close the doors.
Old 29 Nov 2010, 08:51 pm
SCBluePT's Avatar
Hey CREWZIN,is there any question that you cant answer about the PT?Looks like you could take one of these apart and rebuild it yourself.
Old 29 Nov 2010, 08:53 pm
I don't mess around with Turbo questions. Never had one, never had to deal with one. Also don't get into the real technical (inside the engine) stuff.
Honestly, with Haynes, Chilton, the Owners Manual, the illegally downloaded 01-04 Repair Manual and Google, it all makes me look good ......sometimes.
Old 29 Nov 2010, 08:59 pm
WolfmanG's Avatar
have you recently done any work to the car that involves removing the faceplate for the ac/radio? if so there may be a loose wire or a short on the ac control. if not that, then there maybe something blocking the vents.
-Danny Wolfman G
Old 29 Nov 2010, 09:01 pm
WolfmanG's Avatar
sorry guys, i wasn't trying to step on anyone's toes with my post. i guess that's what happens when it takes me 30 minutes to reply.
-Danny Wolfman G
Old 30 Nov 2010, 11:47 pm
ProDigit's Avatar
the vents on my PT have an open/close button, and a secondary on the dash (more like a wind directer...)
Old 13 Jan 2011, 08:35 pm
OK, to update - I ended up at the mechanic who said something slipped off the internal control (blend door screw?) so he redid it and it works fine now. Labor was about $50. Thanks CREWZIN (and gkid1983) for your suggestions!
Old 13 Jan 2011, 08:36 pm
Dang it, I don't know nuthin bout no olde farte NA PT's....lol...
Crewzin, I'm not worthy!
OOPS, sorry, wrong graphic!
Old 22 Apr 2015, 11:24 am
How is this air blend door accessed? Red PT is missing the vacuum line from the brake booster.
2005 PT Dash vents not allowing air flow barhopping General PT Cruiser Discussions 0 12 Oct 2010 04:28 pm
2008 AC vents LoreyCruiser Interior Accessories Forum 2 17 Jul 2010 02:13 am
Need Help! Son dropped something into vents iteachcomputers General PT Cruiser Discussions 7 14 Feb 2009 10:55 pm
Air Vents Stuck on Dash. stabbal Interior Accessories Forum 1 16 Jan 2009 05:51 pm
Chrome vents ? Carbon Fibre dash trim? careyk Canada PT Forum 2 01 Feb 2008 07:44 am
