need help
Old 09 Apr 2011, 11:55 am
Default need help
I had smoke coming out of my 2002 pt. it smelt like a wire burning. i shut down the car. smoking stoped. i turned it back on and i had no dome lights, no power door locks, no radio, and odom is reading no fuse. checked all fuses even the 20amp under hood. before this happened i was having problems with the volume button on the radio, there seemed to be a short in it. don"t know what to do now.
Old 09 Apr 2011, 12:57 pm
Default Re: need help
Check again the IOD fuse (no# 17) in the PDC (power Distribution Center) under the hood. Sometimes it's not easy to detect when it blows. It's not easy to check or take out.
Also, if you think the problem is the radio. Pull out the #13 fuse in the interior fuse box till you get everything working again. Then replace it and see if everything works.
It would also be nice to introduce yourself as this is a forum and not just an "ask a question and leave" kind of site.
Old 10 Apr 2011, 05:50 am
i am sorry if i posted wrong, i used this sight for all my repairs, just by looking at what others post, i have had alot of repairs just in one month from head gasket on down. I will defintley try what you suggested.
