2005 headliner removal
Old 24 May 2011, 08:42 pm
Default 2005 headliner removal
The headliner is sagging in our 2005. I can tell that the headliner is not one piece. It seems to only have paneling on the edges.
Does the 2005 have one piece headliner ?
The previous owner had a sunroof installed.
Were can I buy a headliner if ours is messed up?
Old 25 May 2011, 06:22 pm
xwing777's Avatar
Default Re: 2005 headliner removal
I removed the headliner in the wifes 06' and it was thin fiberglass with cloth material lined with thin foam in between. My 04' looks the same as well so i assume the 05' would be the same.
My bet is when the sunroof was installed they broke the fiberglass in doing so causing it to appear its 2 piece. This would also cause the sag as well.
If it was me, i would remove the headliner, take off the covering and foam (use a wire brush gently after you remove the fabric to get the old foam off)
When clean, go get some tiger hair and repair the broke area. Then recover with material. Check fabric/upholstery type stores and you can use contact cement or 3M spray glue. It may appear daunting but you would be surprised how easy it is and cheap if you do it your self.
Heres my wife headliner i did for her for around $30 and a weekend:
2005 PT Top Removal PIRATE PT Cruiser Convertible Forum 4 05 Apr 2011 02:20 pm
headliner removal instuctions. golf55555 General PT Cruiser Discussions 4 30 Mar 2011 05:09 pm
Spear removal on 2005 vert. surprise purple people eater Exterior Accessories Forum 0 12 Jun 2005 12:32 am
Headliner removal Kammler68 Interior Accessories Forum 7 10 Nov 2004 09:16 pm
Rattle in headliner idigrocks General PT Cruiser Discussions 3 01 Nov 2004 03:34 pm
