Drivers door arm rest
Old 20 Nov 2011, 03:55 pm
white's Avatar
Default Drivers door arm rest
Boy o Boy, the arm rest is really hard. I had made up a pad with foam rubber and covered it with a soft old hanky. That worked OK but I did not glue it down so it was always falling off. So today I am going to make a good one out of 1 inch foam and cover it with some dark gray plastic/leather material. Then I am going to glue it onto the arm rest with some Weldwood contact glue. Don't think the glue will hurt anything and GooOff will remove it with a little work.
If it works and looks OK I will post some photos later.
E. White
2010 Black over Silver, Couture Edition
Old 20 Nov 2011, 08:42 pm
Default Re: Drivers door arm rest
I agree about the armrest being hard.
One might be able to avoid gluing by creating an arm rest that would hold in place by means of a projection from the lower surface, shaped and designed to press into the arm rest opening (hand grab space).
Old 21 Nov 2011, 07:50 pm
white's Avatar
I was going to use a piece of strong tin, but could not get it to slide down next to the door. So I will glue it.
E. White
I need a drivers door DuanefromPA The Detail Shop 8 21 Jun 2010 12:38 pm
Key does not work in drivers side door adriennemetalsmith Sound and Security Forum 4 02 Jun 2010 07:07 pm
Drivers door not latching roborob76 Sound and Security Forum 7 19 Nov 2009 09:03 am
Key won't open drivers door! littleblueGT General Turbo Discussions 3 20 Aug 2007 10:32 am
Passenger Arm Rest.... 2k1PT Interior Accessories Forum 2 30 Jun 2007 07:24 am
