Rear latch Problem Catching
Old 06 Feb 2012, 03:16 am
outfit's Avatar
Send a message via Yahoo to outfit Send a message via Skype™ to outfit
Question Rear latch Problem Catching
Hello everyone,hopefully this is the right forum. My 2006 Touring is having an issue with the right side of the rear hatch sticking and catching on the shock.. When you lift the hatch it catches and pops onthe shock then slowly rises up. I've inspected the shock and have found on the rod that is is rusting at the very bottom . Now has there been problems with the lifting systems(shocks) and is there a better part Ican install to lift the rear hatch. I want tomake it as eesy as possible to rise due to my many lower back surgeries. As soon as the weather clears up I will take some pictures of the shock on the right to show the problem area,or at least what I think it is.
Has anyone else heard of orhad this issue?
<---- Just installed.
2006 PT Cruiser Touring Non-Turbo
3 -Hyper White Thin Flexible 5mm LED Dome Lights from Oznium Damn they make a dif in the inside ,let me tell you the best led lights you can buy
1 -Hyper White 921 Superstar Bulbs from Autolumination
1 -Hyper White T10 Wedge 194 (Lic Pllate) Super White LED from Autolumination
Pioneer Head unit W/ HD & Satellite radio
2 - 7inch DVD/Headrests Monitors... dvd players built in the headrests
HID Lights 8000k 9006 for lows from xhidoutlet....
HID Slim 55w 6000K for high's from HIDGEEK.
Old 06 Feb 2012, 11:46 am
Default Re: Rear latch Problem Catching
i replaced both my hatch struts 2 weeks ago on the wife's pt due to popping and her's was rusting on the bottom as well.
you can also use sandpaper on the rusted area to smooth it out. had to do that to my 2002. worked out pretty well.
Old 15 Feb 2012, 11:10 pm
So after 6 years one the struts is failing. Things of this nature have happened before and will again happen on most of the cars on the road today. It's not just the PT. That being said, if I were you I would change at least just that one as soon as the the weather permits. Simply because it makes no sense to wait.
As was said above, using sandpaper will probably give some temporary relief, but you're going to end up replacing it sooner or later.
Jerry
Help! Rear driver side door will not latch! nobodysfool55 General PT Cruiser Discussions 7 17 Feb 2011 09:17 am
Brakes Catching ptcruisefl Tech & Performance Forum 1 10 Jun 2010 03:55 am
Steering Catching kelecoleman General PT Cruiser Discussions 3 16 Apr 2010 02:22 pm
Back Latch Problem michele66 Tech & Performance Forum 2 21 Sep 2008 04:00 pm
Rear hatch latch issue oldcoach General PT Cruiser Discussions 0 30 Jul 2007 10:00 am
