Removing drivers side cargo area side panel
Old 24 Mar 2012, 09:32 pm
Send a message via Yahoo to Jtwheels2007
Default Removing drivers side cargo area side panel
Has anyone ever removed this panel? I am planning on doing an install that requires running wires from the dash, back to the rear of the car. I know removing this panel is more than just the couple of phillips head screws. can anyone give me a step by step?
Old 25 Mar 2012, 10:36 pm
Default Re: Removing drivers side cargo area side panel
It's not hard, but several other trim pieces need to come off. Everything will be held by screws or press in (pull out) clips. Don't force anything until you are sure that all screws, bolts have been located.
Fold and tumble your rear seat forward after removing the rear door sill plate trim.
This info is cut and pasted from the 2004 shop manual.
UPPER C-PILLAR TRIM
REMOVAL (See removal of rear seat belts below)
(1) Disengage clips attaching trim to C-pillar
(2) Remove upper trim panel from vehicle.
DOOR SILL TRIM (rear side door and rear hatch)
REMOVAL
(1) Open door to gain access to sill trim.
(2) Disengage clips attaching sill trim to door sill.
and door opening flange.
(3) Remove door sill trim from vehicle.
UPPER D-PILLAR TRIM
REMOVAL
(1) Disengage clips attaching trim to D-pillar.
REAR SEAT BELT &
RETRACTOR
REMOVAL
(1) Remove turning loop cover.
(2) Remove turning loop bolt.
(3) Remove upper and lower trim bezels.
(4) Remove trim panel from body, refer to BODY/INTERIOR/LEFT QUARTER TRIM PANEL REMOVAL).
(5) Remove lower seat belt anchor bolt.
(6) Feed seat belt and hardware through trim
openings.
(7) Unbolt and remove the retractor and belt
assembly.
LOWER QUARTER TRIM
PANEL
REMOVAL
(1) Remove upper quarter trim panel.
(2) Disengage clips attaching trim to lower quarter
trim panel.
(3) Remove cargo tie down trim panel.
(4) Remove lower quarter trim from vehicle.
Attachment 4894
Old 26 Mar 2012, 08:03 pm
thanks. seems simple enough. description kind of vague but seems simple enough
drivers side front fender for 03 randymandy Classifieds: For Sale/Trade 8 31 Jan 2017 10:37 am
Drivers Side Gets Loud TwoToneTommy Wheels, Tires, Suspension 3 24 Feb 2010 09:12 pm
Some A-hole cut my top on the drivers side MINIHEMI46 PT Cruiser Convertible Forum 21 02 Jan 2010 11:37 pm
Drivers Side Headlight 2k1PT Classifieds: Want To Buy 2 23 Aug 2008 03:39 pm
Cap in drivers side fender wheel? DannyR General Turbo Discussions 14 17 Feb 2006 02:18 pm
