SRT Gauge
Old 22 Apr 2012, 09:13 am
Default SRT Gauge
This is probablly a stupid question but I ordered a SRT Autometer Pro-Comp Ultra Light Boost Gauge for the PT and was just wondering if anyone had the it and could give me the dimensions on it. Id like to fit it in a 52mm steering column gauge pod but im not sure if its to big or to small for the pod. If anyone can help thanks a bunch
Old 22 Apr 2012, 06:05 pm
compdr59's Avatar
Default Re: SRT Gauge
Please post a picture when your project is complete. I may want to do the same.
Original Owner 135k
Old 22 Apr 2012, 06:42 pm
Kawizx9r's Avatar
Wherever you ordered it from should have the dimensions available...so I don't see why you're asking?
If the gauge is too big, you could always trim away at the gauge pod with a dremel or similar type tool. Just be careful not to scorch/melt the plastic if you do have to trim it.
Also, when you're tapping your lines for your vacuum line make sure to use zipties on everything to ensure nothing comes loose.
Kawi is a friggin genius!
Old 23 Apr 2012, 06:40 am
the gut im buying it from wont reply back on the gauge however, i did some math gettin info elsewhere it comes to 52.3mm for the srt gauge so it should work fine after i take it of the housing
Tags
gauges
Gauge Brendas Tech & Performance Forum 1 03 Oct 2011 03:11 pm
Gas Gauge rudy04pt The Detail Shop 6 14 Feb 2011 07:03 pm
WANTED SRT Boost Gauge and SRT EGT Gauge. Hiperguy Classifieds: Want To Buy 4 13 Oct 2010 06:15 pm
Gas Gauge Kimosd1 General PT Cruiser Discussions 0 03 Mar 2010 07:51 pm
this gauge looks too good to be true - does it work ? interceptor gauge mino General Turbo Discussions 3 18 Oct 2007 08:58 pm
