SRT Gauge-Match made in Heaven
Like Tree5Likes
Old 26 Apr 2012, 04:48 pm
Default SRT Gauge-Match made in Heaven
Just got the SRT gauge in, took off the casing around it and this is what it looks like in the pod. Such a nice fit
XtrmDC2 and cruisin03pt like this.
Old 26 Apr 2012, 05:08 pm
Default Re: SRT Gauge-Match made in Heaven
NOW were talkin, shorten the casing looks awesome
Old 26 Apr 2012, 07:22 pm
ROCKETMAN8060's Avatar
Very nice! Love it!!!!
ROCKETMAN8060
Old 29 Apr 2012, 10:42 pm
Your gauge is faulty if the needle does not sit at Zero when the motor is off.
FYI.
03GTCruiser likes this.
Old 30 Apr 2012, 06:41 pm
xwing777's Avatar
you can adjust it by sticking a screw driver in the back and slightly bending the arm. Hard to explain but stick a phillips in the back and watch the dial move as you push the curved band inside and you will see what i mean.
Old 30 Apr 2012, 08:58 pm
o my bad this is just a mock been too busy to get it done ill post pix once its up and running, I managed to get good power just have to do the vaccum line maybe tommorow if i get time
Old 30 Apr 2012, 10:35 pm
03GTCruiser's Avatar
I hope you got a super good deal on the gauge. It looks good, but they are prone to failure and false readings. If you can't get it adjusted to sit at zero, the autometer pro-comp looks identical, except it doesn't say srt.
Sold 2003 Pt Cruiser GT Autostick. Sold
Now a slow 2009 Pontiac vibe 2.4l 5-speed.
http://www.ptcruiserlinks.com/forum/image.php?type=sigpic&userid=9656&dateline=1247691  818
227 HP and 281 TQ
new best of 14.56 1/4 mile on 7/25/12 still using the canned tune from my diablosport predator.
*Stage 1, DSP w/93 canned tune, 3" o2 housing, 3" FWDPerformance downpipe with cutout. Bwoody solid mounts. AMX1397 TTAB with K&n drop in filter and airbox mod. AMX1397 lower pipe and AMX1397 uppipe with HKS BOV
* stock nsrt rims powdercoated black, chrome pillars.
* 3 gauge pod w/ aem wideband, Autometer ultralite oil pressure and 30/30 boost, Mopar 8" sub.*
Old 30 Apr 2012, 11:01 pm
LittleMissE's Avatar
I have been trying to convince my boyfriend since I got my GT that he needs to get a boost gauge that reads higher for his stage 3 SRT-4 so that I can have his gauge. Right now his gauge just pegs out all the time. And I want one that doesn't fludder (it seems like a really cheap gauge that came with the car).
Old 15 May 2012, 04:15 pm
Sounds like your boyfriend is lazy. Maybe you need a different boy friend lol
Old 15 May 2012, 05:52 pm
Don't adjust the gauge setting to zero until you've installed it and had it connected up while the engine is running. Sometimes you'll get a pull on it, or even a slight push, after the engine has run and that will sometimes zero out the gauge. So make sure you use it first, then if it's not to zero go ahead and adjust the display armature.
12v DC port add-on, paint to match? THS_Cruiser03 Interior Accessories Forum 2 14 Jan 2010 03:51 pm
Perfect Match jumbo390 Wheels, Tires, Suspension 4 20 Jul 2004 01:00 pm
GT no match for SRT-4 MEXICANPT Stage Turbo Kits 32 21 Dec 2003 05:41 pm
Cruiser Quarterly arrived . . . I'm in heaven GTSteve General PT Cruiser Discussions 10 02 Nov 2003 11:22 am
