Dashboard Defroster Grille
Like Tree2Likes
Old 23 Nov 2012, 12:25 pm
Default Dashboard Defroster Grille
Anybody know where I can get a dashboard defroster grille?
The one that defrosts the windshield?
Or maybe a fix?
Old 23 Nov 2012, 08:57 pm
Default Re: Dashboard Defroster Grille
The grill comes with the dash top (not sold separately). There has been somebody awhile ago that came up with a fix after his broke. I'll see if I can find it.
2001 Limited defroster grille/vent/whatchamacallit
Cracked PT Cruiser Dash Cover
http://www.allpar.com/forums/topic/1...-vent-in-dash/
Large dash vent breaking apart
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 27 Nov 2012, 08:11 pm
If you can't find one, let me know, I have a friend who runs PT Parts Warehouse on Ebay. He is good at finding things that people need and sells them at good prices.
Old 29 Nov 2012, 10:05 pm
You know .... with all of the aftermarket accessories that have been made for the PT Cruiser, you'd think SOMEbody would have made an aftermarket drop-in replacement for that grill, seeing how widespread a problem it is.
Just make a replica of the grill with a flange around the outside edge. Cut out your old one and drop the new one in place.
So many of the aftermarket "add-ons" I wouldn't put on a parade float - c'mon you aftermarket guys, here's a useful after-market part we can REALLY use !
Mark.
Old 30 Nov 2012, 09:30 am
Aftermarket didn't make on but Chrysler did! Well not on purpose. The brezze and it's other counterpart have a removable grill that gives the same look. I installed one for a friend. It's a slight different shape on the windshield side. Only noticeable if you installed one. Early 0s, check at your local wreckers.
I even found the same color!
zamfir2 likes this.
Old 01 Dec 2012, 10:44 am
Now that's an interesting tidbit .... I know there's some of those in my local wrecking yard - will have to grab one and see. Thanks.
Mark.
Old 01 Dec 2012, 12:56 pm
I saw one in a brezze in the late 90s just yesterday. So I'm not sure how many years have these. Cutting the hole to the correct size is critical in getting it to hold itself in.
Old 01 Dec 2012, 02:21 pm
So it's not just a matter of cutting out the old grill itself ? The hole needs to be larger than the original opening without the grillwork ? I was hoping to just cut out the broken / cracked grill work (leaving the original frame) and drop it in. Not so ?
Mark.
Old 01 Dec 2012, 04:28 pm
A little more work than that. But to look at one you would think it fits right in. Once in it looks totally original. If you take it out your self, it would be nice to trace the opening for a pattern. It will pry out of the dash. It is flexible.
Old 23 Feb 2013, 04:48 pm
I did this today. It works great! The part you need is from a 1st generation Cirrus/Stratus/Breeze, 1995 through 2000. An online catalog I saw says a 2000 Dodge Ram uses the same part, but I haven't checked that.
Busted_PT likes this.
Rear Defroster trinadawn General PT Cruiser Discussions 3 14 Oct 2012 02:08 pm
Defroster trinadawn General PT Cruiser Discussions 1 28 Jan 2011 01:39 pm
defroster problem ptjoe General PT Cruiser Discussions 0 04 Feb 2010 12:04 pm
2001 Limited defroster grille/vent/whatchamacallit redrider02 Interior Accessories Forum 13 03 Aug 2009 05:17 pm
