PT Cruiser Forum Car Videos
Custom Wheels
Speedhut Gauge kits now avail for preorder
Old 02 Mar 2004, 08:39 pm
JaxPT JaxPT is offline
Default Speedhut Gauge kits now avail for preorder
http://speedhut.com/15orders_el_deta...mber=62&bhcp=1
finally I made progress with speedhut, the gauge kits are on the website at the link above[^][?]. i'm still working on the details and i'll pass the info along ASAP.
Old 03 Mar 2004, 01:33 am
IRPT IRPT is offline
Should we go ahead and place our pre-order?
2002 Inferno Red PT Limited
Mercedes Wiki
Old 03 Mar 2004, 10:03 am
How difficult is the install? do understand that you can get custom lights for it? gary
Old 03 Mar 2004, 07:43 pm
ptcruzin42 ptcruzin42 is offline
Send a message via AIM to ptcruzin42
i'm ready to pre-order now but when I try to do it on the page it wants to go ahead and charge the whole 100 dollars....what do we do?
Life dealt me a hand and I\'m bluffing hard, I\'m playing poker with a joker and some uno cards.
Old 03 Mar 2004, 07:56 pm
ptcruzin, it appears to charge the whole amount, actually all you will only be charge is $1.00 (non-refunable) until the item is shipped, then the balance will be charged.
There are some many combinations I can't make up my mind. It's going to take me a while to decide what I want. What are others getting?
Mercedes Wiki
Old 04 Mar 2004, 02:23 am
"5. How can I place a Pre Order?
Please click on the MODEL DEVELOPMENT PROGRAM link (listed on the Home page). Find your Make/Model/Year and click on the link. You can place your Pre Order by going through the Checkout.
Your Credit card will be Charged $1.00. This amount is Non-Refundable. Once the Pre Order has been tooled up the full amount will be charged. The $1.00 charge will be credited towards this amount. "
The option for the N/A or turbo is on the last page of the order section under options
I stay in contact with Aaron at speedhut and pass along any questions you may have. alot of answers can be found in the speedhut FAQ section
Old 04 Mar 2004, 12:30 pm
yobiebs yobiebs is offline
Send a message via AIM to yobiebs
What's the difficulty level on the install for something like this?
2003 Electric Blue GT
The Philadelphia Flyer
Old 04 Mar 2004, 02:39 pm
I think it's basicly teh same as the nu image gauge faces just more customizeable. i pulled the install instructions from nu images website, this should be the same
Installation Instructions for the Pt Cruiser
1) To start the install, the vehicle must be cold. Start it up and make a sketch of what the gauges are reading. Mark the needle location exactly.
2) To get to the gauges, you must remove parts of the dash. First, you will need to grab the panel directly below the steering column and give it a slight tug at the top. It will reveal 2 screws at the left. Remove and pull of gently.
3) The a/c control knobs need to come off and can be done with a slight tug. Once removed you can now remove the window controls between the two center a/c vents, in which will uncover 2 screws to pop the upper part of the dash up.
4) The upper a-pillar cover is next to come off and can be removed by pulling the rubber seal away from it and popping it off. This allows the top of the dash to go up freely.
5) Remove all screws holding the gauge cluster and take it out.
6) Depress tabs on the clear window and remove.
7) Now that you have access to the gauges, you will need to remove the black needle stops on the original gauges because they will used on your NU Glo Flame gauges.
8) Use the needle removal tool that is included in the kit and remove the needles gently.
9) Remove the OEM gauges and discard. Place the Glo Flame gauges on the cluster.
10) Now insert the needle stops in there original location.
11) Now reinstall the cluster with out the needles on and start it up. Carefully place the needles on the gauges where you marked them in step 1.
12) Reinstall all the parts of the dash to complete the installation.
not too difficult i've already removed and replaced most of those parts for other installations
Old 04 Mar 2004, 04:01 pm
Gear_Head Gear_Head is offline
I just ordered one too. That is the only way I'll get the stock gauges to match thr Autometer pro-comp gauges....
Old 04 Mar 2004, 11:07 pm
ordered mine
vB code is On
part numbers Punch General Turbo Discussions 5 13 Jan 2004 11:46 pm
Mopar Gauages and Stage 1 kits in Canada GLH_TC 16V Vendors & Buyers Forum 1 12 Sep 2003 12:57 pm
Boost Controller and Gauge Questions Dalite Turbo Performance 13 14 Jul 2003 01:20 pm
FS: Dual Gauge Pod jramosGT Classifieds: For Sale/Trade 3 22 Apr 2003 06:57 pm
Ins5tall of Water Temp Gauge jramosGT Tech & Performance Forum 1 01 Feb 2003 07:42 pm
  GameCheatsCodes | Debt Consolidation | Online Advertising | TurboTax | Property in Spain
