speedometer light dim
Old 04 Feb 2013, 10:11 am
Default speedometer light dim
I have a 2003 with 101k miles. I recently had the control arm bushings and cam position sensor replaced. (I think it was the fourth time for the latter repair!) Last night, I noticed that the red arm that shows the speed was unlit or dim. This morning, that was still the case, but the right side of the speedometer (around 120-140mph) and left side of the tachometer were dim. Any ideas what this could be?
Old 04 Feb 2013, 10:35 am
Default Re: speedometer light dim
If some are bright, then you have some burned out bulbs. You will need to remove cluster to replace. Replace all not just the bad ones. Others may go anytime if left in there. Not worth the risk if already out. If all are dim check your switch position.
Old 04 Feb 2013, 01:04 pm
i concur with busted. there's a sticky in the "how to" section for removing the cluster.
2016 Kia Soul Plus Black
Speedometer bennyhill007 General Turbo Discussions 6 26 Oct 2012 10:05 am
Speedometer Light(s) Burned Out mcrice02 Exterior & Interior Styling 2 07 Feb 2012 01:18 pm
Speedometer light out rockhillcruiser General PT Cruiser Discussions 2 09 Oct 2011 03:45 pm
01 Speedometer light stephhughesmn Tech & Performance Forum 4 04 Sep 2011 03:07 pm
speedometer 4SPEED Tech & Performance Forum 2 29 Sep 2006 05:00 pm
