2006 seats
Old 21 Jun 2013, 10:05 pm
Default 2006 seats
I purchased a set of leather seats from a 2006 pt cruiser figuring the would swap into my 2006 easy enough. I put the passenger seat in today. Easy install including wiring plug (same as in car). However, when I start the car the airbag light stays on. Anyone know what might cause this? I haven't put the driver's seat in yet. Thanks!
Update to above. I re-checked and the leather seat has an extra plug (yellow) that the cloth seat didn't. Is the yellow plug an airbag connector? If so, anyone know how to bypass this or will I need to get a different harness (chassis)?
Old 21 Jun 2013, 10:36 pm
randyincctx's Avatar
Lightbulb Re: 2006 seats
I may not be as knowledgeable about PT's as some on here...But,in general I know some things.....Did you disconnect your negative battery terminal when you did the passenger seat swap?......If Yes,then have you tried unplugging & plugging the passenger seat wiring harness again?...Just my .02 worth of auto knowledge.
Aka:~KILLER~
Old 21 Jun 2013, 10:54 pm
Default Re: 2006 seats
Thanks. No I didn't. I'll give it a try.
Old 21 Jun 2013, 11:12 pm
Exclamation Re: 2006 seats
Anytime your going to connect or disconnect ANY electrical component,it's highly recommended that your disconnect your negative(-) battery terminal,especially in cars equipped with SRS(airbags)........Also,disconnecting your battery will do a reset of the cars computer module(ECM)....Note: The car may idle rough for a few seconds to a few minutes afterwards.
Aka:~KILLER~
Old 21 Jun 2013, 11:13 pm
needmoretoys's Avatar
Just be very careful. Airbags are nothing to mess around with. Please keep your face clear just in case it goes off. Yellow plugs for air bags have some sort of safety clip that makes them stay on.
Lenny
FEBRUARY CRUISER OF THE MONTH
Old 22 Jun 2013, 06:09 am
Good advice everyone. Thanks!
Old 22 Jun 2013, 01:11 pm
Talking Re: 2006 seats
I assume that means it worked?
Aka:~KILLER~
Old 27 Jun 2013, 01:06 pm
Randy,
No, still not working yet but these were good to know, particularly about disconnecting the negative lead. I think I need to get a wiring diagram to find out were the yellow connector attaches. While the "big gray plug" fit fine I think the computer is looking for info coming from what's attached to the yellow plug and without that info, it's assuming there's a fault. Just a guess, but it sounds reasonable to me. When I get this working, I'll let you know what the fix was.
Chris
Old 27 Jun 2013, 04:52 pm
Cool Re: 2006 seats
I'm not able to go look at mine but can you tell if it's a 2-wire plug?.......If it is;Maybe you can try putting a 'U-shaped' jumper wire as a bypass.(Disclaimer: I am not responsible for any bodily injury incurred in an accident by deployment/non-deployment of SRS airbags!LOL) ...........Have you considered that the seat may have a bad sensor???...The "seat sensor" is called an occupancy sensor, and is located in the seat cushion. It detects when enough weight is placed on the seat to activate the airbag. They're replaced by pulling off the seat cover, and it's located right on top of the seat cushion.They can be broken by placing abnormally shaped objects in the seat, such as kneeling on the seat, or any kind of blunt heavy object.
Aka:~KILLER~
Old 27 Jun 2013, 05:06 pm
I,ve done some checking online....One way to test if it's the 'seat occupancy sensor' that is bad....Buckle the passenger seatbelt(with no weight in the seat)and if the airbag light goes off then the sensor is probably OK,and your back to square one.
Aka:~KILLER~
Replacing seats 2001 PT into a 2006 PT?? Wiredright Interior Accessories Forum 3 28 Feb 2013 11:31 am
Cleaning 2006 PT Cruiser Seats jkranites The Detail Shop 5 16 May 2012 08:02 am
Missing rear seats for 2006 PT roxie0664 Interior Accessories Forum 2 01 Dec 2010 11:17 am
Child convertible car seats that fit in a 2006 PT lsfcdf General PT Cruiser Discussions 0 04 May 2009 11:42 am
2006 PT Seats Interchange with older models? rickp44087 Interior Accessories Forum 7 17 Feb 2009 01:52 am
