Glove Box Light
Like Tree3Likes
Old 10 Jan 2014, 10:31 pm
randyincctx's Avatar
Lightbulb Glove Box Light
I was wondering if anyone has tried a mod of this kind;I've given it some thought using these parts:
LED LIGHT-http://www.ebay.com/itm/121247902560...84.m1436.l2649
PIN SWITCH-Adjustable Pin Switch for Car Alarm Trunk Door w Female Quick Disconnect | eBay
This is my basic idea......Feel free to opine.
Aka:~KILLER~
Old 10 Jan 2014, 10:35 pm
InfernoGT's Avatar
Default Re: Glove Box Light
Sounds like a good Idea to me! Wire it to a constant 12v and as long as the switch is wired "normally closed" it should turn out fine
2006 PTGT with 5spd. ~60k miles
Old 10 Jan 2014, 10:57 pm
Lightbulb Re: Glove Box Light
I thought 'keyed' 12v would be better,in case somebody (ME?) happens to leave the glove box open,it won't drain the battery........That particular pin switch is 'normally open' (when depressed),when the glove box is opened(pin switch out),then the circuit will be closed,and the light will turn on.
Aka:~KILLER~
Old 10 Jan 2014, 11:51 pm
sanatanadharma's Avatar
I used an LED light strip fastened along the upper edge above the open box.
When closed this strip is unseen; it shines down into the full width of the box.
I did wire to an always hot source.
I used a magnetic switch such as used for home window security. The magnetic half is attached to the backside of the glove box. It triggers the wired portion mounted to the heating duct behind. The light is off before the door is fully closed. When the glove box is removed completely for any work, I disable the hot lead via an installed connector.
Old 11 Jan 2014, 12:20 am
soonercruiser's Avatar
Thumbs up Re: Glove Box Light
Gotta figure Smurf had another way to do that!
HEY CREWZIN!!!
Sounds like a couple of potential "How To" stickies that need done with pictures.
(So that I'll know how to do it when I'm brave enough...)
Frank, aka SOONERCRUISER,
2010 Dodge Challenger SE as my day-driver.
2005 "Limited", Stage 1 Turbo Lite, the "Cowboy Cruiser".
Have now owned 5 PT Cruisers = Me PT Crazy!
Old 11 Jan 2014, 04:05 am
Actually I did think about lighting the glove box. But went against it as I thought how many times are you in the glove box and need a light. My response, not enough. So I just put a cheap flashlight in the glovebox as I had one in my car anyway.
I also thought (and actually tried) lighting the power mirror switch along with the door locks bur thought against it as well as I don't lock my car with the door locks and the power mirror switch won't been seen whilst sitting.
soonercruiser and LionPT like this.
Old 11 Jan 2014, 08:14 am
pappa, you should light the the under the seat drawer. I like the magnetic switch thing from Sanatanadharma's post. So you may as well light up those other things you mentioned above too .
Old 11 Jan 2014, 02:00 pm
This is why I dismiss the idea off hand.
And, I put a small LED flash light there in the case that I ever need to see some detail at night.
It's kinda like the glove box trim too.
If I can't see it off hand, I am apt to not worry about appearances.
LionPT likes this.
Old 11 Jan 2014, 02:58 pm
Originally Posted by Busted_PT View Post
pappa, you should light the the under the seat drawer. ...too .
Oh great! Now I have another project that, once finished, I will attribute to another's idea; this time your's Busted...
Old 11 Jan 2014, 05:13 pm
That's funny;Because I had also thought of that,but couldn't figure out a way to switch it on/off....Since a pin switch isn't a viable option there,but a 'magnetic switch',and then tap into the wiring for the gear shift indicator light,to power it(MTXs have the socket,it's just not being used!).
I've already ordered the LED & switch for the glove box,and I think that once anybody adds a light to a glove box,or 'other things'......That gives you a reason to use it more.
Aka:~KILLER~
09 Glove box Merlin1 General PT Cruiser Discussions 1 18 Sep 2010 02:41 pm
GLOVE BOX ORGANIZER MAESTRO Interior Accessories Forum 14 14 Jun 2004 08:19 am
GLOVE BOX ORGANIZER R.E. Interior Accessories Forum 0 10 Jun 2004 09:49 pm
Glove Compartment Light rnbenoit General PT Cruiser Discussions 1 09 Apr 2004 09:55 pm
no glove box light ??????? SHOVEL100 Exterior & Interior Styling 4 03 Jul 2003 09:52 pm
