Interior LED light Help
Like Tree2Likes
  • 1 Post By CREWZIN
  • 1 Post By njsteve1
Old 08 Feb 2014, 07:09 pm
Default Interior LED light Help
Since 1 mod leads to another, what to upgrade my interior lighting.
search, but confuse.
05 Vert
Mirror lights / T192
Center Console light / T37
Cluster / 74
What are the best replacement LED bulbs?
Also saw a post on a upgrade on the cluster bulbs but not LED.
Any help to unconfuse me would help.
Thanks
Original join date: SEP 2003
Steve/ Wayne NJ
2005 GT Vert / Black / 5 speed
2004 Dream Cruiser / 5 speed Traded for 12 Veloster
2003 GT / Blue / Auto /sold
2001 Touring/ Silver / 5 speed /sold on E Bay
Old 08 Feb 2014, 07:25 pm
Default Re: Interior LED light Help
See if this helps at all....
Interior LEDs (In my 01 cruiser )
Gemm75 likes this.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 08 Feb 2014, 07:51 pm
randyincctx's Avatar
Lightbulb Re: Interior LED light Help
THe best site for everything LED seems to be this one: LED Lights, Bulbs & LED Lighting Accessories - SUPER BRIGHT LEDS
The best are those that provide 360 degrees of illumination(no dark/bright spots)
The equivalent LED replacement bulb for ALL the applications you have listed is this one:
Search Results For "wedge 74" | 74 LED Replacement Bulbs for Cars | 12v | Super Bright LEDs
For all of those applications you will need to decide if you want 'warm white'(brighter & less white/slight yellow) or 'cool white'(brighter & very white).......For the instrument cluster(total of 8 bulbs=3/turn signals & high beam indicators + 5/gauges & needles),instead of ALL warm or cool white,you may want to try this option: 3-'cool white' for (2)turn & (1)high beam indicators,3-'blue' for gauge 'faces',2-'red' for needles,these choices work well with the stock color spectrum of the gauges & needles,some other choices do not......For more info on this see(click 'how-to guides list',then select 'change dash bulbs'):http://www.streetcruiser.co.uk/
Aka:~KILLER~
Old 08 Feb 2014, 09:39 pm
Thanks Randy
So I get this right
All three different sizes replace with wedge 74
using the how to pic
cool white
2 mirror
1 console
1 high beam/ shown as main beam
2 turn signal
blue
3 for #1,4,5
Red
2 for #2,3
use this bulb which is the only 360 degrees shown
74 LED Bulb - 3 SMD LED Wide Angle Wedge Base | Instrument Cluster and Gauge | LED Car Bulbs | Super Bright LEDs
randyincctx likes this.
Steve/ Wayne NJ
Old 08 Feb 2014, 10:08 pm
Thumbs up Re: Interior LED light Help
Originally Posted by njsteve1 View Post
Thanks Randy
So I get this right
cool white
2 mirror
1 console
2 turn signal
blue
3 for #1,4,5
Red
2 for #2,3
Looks like you got it all covered....Not to confuse you but you could go with 2 'green' for the turn indicators,and 1 'blue' for the Highbeam,but they are normally bright enough with the 'cool/warm whites' LEDs.
The whole 'color spectrum thing' is: "Based on the given color of the ''filter",a bulb of a similar color will generally enhance the particular color,more than a 'white'/normal bulb will;Whereas a bulb of an 'uncomplimentary' color will be filtered-out,by the particular color of the filter.
Example: If using a 'purple' bulb with a 'blue' filtered gauge face,the blue color of the purple bulb will be filtered out,actually causing the gauge faces to appear darker.
Important Tip: LED bulbs are 'polarity specific',generally the load resistor needs to be installed on positive(+) side of the socket.....So,if the first time you install the bulb(s) some don't light up,just pull & reverse them into that particular socket,and then they should work correctly.
Aka:~KILLER~
Old 08 Feb 2014, 11:07 pm
Thanks again will order soon.
I will need to use my existing sockets for each lamp?
Any Pics?
Steve/ Wayne NJ
Old 09 Feb 2014, 12:13 am
Post Re: Interior LED light Help
Any Pics?
The vanity mirrors,center console flood lamp,and turn signal indicators have their own 'built in' sockets;The 6 sockets for the cluster are reuseable PC twist-sockets(a PC74 is just a #74 bulb in a PC socket base),simply twist the PC74 out,then pull the #74 bulb out,and install the PC socket w/LED bulb now installed back into the cluster.
This Ebay add shows what the PC sockets look like(it shows a different style of 3-SMD/LED bulbs in the photo):
10x PC74 3 SMD Twist in Instrument Panel Dash Light LED Bulb PC Sockets T5 Red | eBay
Aka:~KILLER~
Old 15 Mar 2014, 10:09 pm
Finally next on my list. Started putting in the leds in the spare sockets for the cluster. A little hole on the bottom of the socket helps to push the old bulbs out.
Just wanted to update. The vert has 2 bulbs in the rear view mirror housing that I got mix up with the vanity mirror.
They are called "overhead reading light" they take a T192 bulb which I hope I crossover right to a 194 led. Need to order them.
Might as well also order the back up light bulbs (3156)
Steve/ Wayne NJ
Pwr windows, Interior AC/Fan and Air Bag light on Retrofn General PT Cruiser Discussions 10 29 Jul 2015 07:39 pm
Interior Light rotty Tech & Performance Forum 5 24 Nov 2012 05:09 pm
interior led, map light and dome light pics outfit Interior Accessories Forum 29 23 Jul 2011 04:42 am
Small interior light Shiniquiet General PT Cruiser Discussions 1 02 Dec 2009 03:35 pm
Interior light popped on. Bdog Tech & Performance Forum 1 18 May 2008 10:26 am
