interior swap
  • 1 Post By iBorg
Old 10 Apr 2014, 11:40 am
Default interior swap
Hi folks only had my PT siince 09/04/14 and already i am looking to change things.
Been offerd a full leather/sued interion with door cards for 50 and would like to swap the old one out to make this look a bit better, i have the classic 2.l on a 54 plate full dealer stamped looking not bad for the age.
now seats will be a straight bolt out bolt in on the front and quick release on the rears, but i want to get the heated seats working as well so my question is, does the power feed to the drivers seat power the heated element aswell as the motor to move the seat or is a different harness needed? i assume that the passenger seat will need a power feed as that doesnt have one on the classic
any help on this would be great many thanks
Old 10 Apr 2014, 11:59 am
Default Re: interior swap
Contact sanatanadharma. I always sell it wrong. But he has done some of this. He Is the electrical guy. Maybe he can help you.
Old 11 Apr 2014, 04:55 pm
thanks for the info will ask
Old 11 Apr 2014, 05:46 pm
sanatanadharma's Avatar
Greetings
Welcome to the forum.
I may be able to help. I assume you are in Europe, but I can not assume the model year of your car. I have some understanding of the wiring schematics for 2001-2005. From 2006 on, with the changed electrical system, I have no knowledge.
Basic system (first gen) uses PDC fuse #4.
In the dash fuse-block fuses #4 (power seats) and #17 (heated seats). Also dash fuse-block fuse #6 (ignition switch power) controls the heated-seat relay at the bottom of the dash fuse-block.
Wiring harness/ connectors for the seat heaters and switches and control modules will likely require some auto salvage yard visits.
Originally Posted by fluffybunnykiller View Post
Been offerd a full leather/sued interion with door cards for 50 ... i have the classic 2.l ... i want to get the heated seats working as well so my question is, does the power feed to the drivers seat power the heated element aswell as the motor to move the seat or is a different harness needed? i assume that the passenger seat will need a power feed...
Old 11 Apr 2014, 08:07 pm
The heated seats are made up of three components, the switches, heating elements and one "brains unit". On a typical US car, the seats have a yellow plug which is for the air bag and a second unit which powers the seat. I would plug in the seat (US is a black plug) and check to see if it works. Try the unit with the controller. The US units are white and are about 3x5 inches and an inch tall typically in the front of the lower seat pan.
Here's what I have for wiring information.....once again US model, European may be different:
PASSENGER HEATED SEAT CUSHION (NORMAL BUILD) - 4 WAY CAV CIRCUIT FUNCTION
1 Z122 18BK GROUND
2 P130 18RD/TN PASSENGER SEAT HEATER B(+) DRIVER
3 P142 20TN/DB PASSENGER SEAT TEMPERATURE SENSOR INPUT
4 P144 20BK/LG PASSENGER SEAT TEMPERATURE 5V SUPPLY
DRIVER HEATED SEAT CUSHION (NORMAL BUILD) - 4 WAY CAV CIRCUIT FUNCTION
1 Z121 18BK GROUND
2 P131 18RD/DG DRIVER SEAT HEATER B(+) DRIVER
3 P141 20TN/LB DRIVER SEAT TEMPERATURE SENSOR INPUT
4 P143 20BK/DG DRIVER SEAT TEMPERATURE 5V SUPPLY
PASSENGER HEATED SEAT MODULE (NORMAL BUILD) - GREEN 14 WAY CAV CIRCUIT FUNCTION
1 P8 20LB/WT PASSENGER HEATED SEAT SWITCH
2 P142 20TN/DB PASSENGER SEAT TEMPERATURE SENSOR INPUT
3 - -
4 F98 18RD/WT FUSED HEATED SEAT RELAY OUTPUT
5 P130 18RD/TN PASSENGER SEAT HEATER B(+)
6 F98 18RD/WT FUSED HEATED SEAT RELAY OUTPUT
7 - -
8 P144 20BK/LG PASSENGER SEAT TEMPERATURE 5V SUPPLY
9 - -
10 - -
12 P138 20VT/LG PASSENGER SEAT LOW HEAT LED DRIVER
13 Z122 18BK GROUND
14 P140 20VT/BK PASSENGER SEAT HIGH HEAT LED DRIVER
DRIVER HEATED SEAT MODULE (NORMAL BUILD) - GREEN 14 WAY CAV CIRCUIT FUNCTION
1 P7 20LB/BK DRIVER HEATED SEAT SWITCH
2 P141 20TN/LB DRIVER SEAT TEMPERATURE SENSOR INPUT
3 - -
4 F99 18RD/WT FUSED HEATED SEAT RELAY OUTPUT
5 P131 18RD/DG DRIVER SEAT HEATER B(+) DRIVER
6 F99 18RD/WT FUSED HEATED SEAT RELAY OUTPUT
7 - -
8 P143 20BK/DG DRIVER SEAT TEMPERATURE 5V SUPPLY
9 - -
10 - -
11 - -
12 P137 20VT/DG DRIVER SEAT LOW HEAT LED DRIVER
13 Z121 18BK GROUND
14 P139 2OVT/WT DRIVER SEAT HIGH HEAT LED DRIVER
It looks like it's a 20A circuit for the power/heated seats. The seat heaters work off of 5 volts, so I hope you got the control modules for them too. Hope this helps you.
Busted_PT likes this.
Old 12 Apr 2014, 07:55 am
thanks for the welcome and the reply's to my post.
the interior that i was offered looked nothing like the interior i was shown in the pics, so i have decided to not go down this route just yet, i got the feeling that the seller was trying to pass off a rubbish interior and not the one he had taken pics off. good job i listend to my instinct
Yes i am in Europe and i would not be surprised if teh wireing was differant between regions, my cruiser s a 2005 on a 54 plate 2.l classic so it lacks some of the refinements of higher spec cars but i will address these as i become more familiar with them and what may or may not fit.
Just had to replace the tail lift gas struts as one side had rusted and was knocking when the tail is opened, just painted them dark metalic blue to match the body colour and i must say it does look rather nice
Radio Swap sadiespoppa Interior Accessories Forum 5 16 Jun 2008 11:12 pm
2.4l Pt swap fork_in_the_road Classifieds: For Sale/Trade 0 03 Oct 2007 09:21 am
engine swap INFERNODPPT Tech & Performance Forum 21 29 Oct 2005 10:00 pm
Engine Swap macster Turbo Performance 3 24 Feb 2004 12:01 am
SRT-4......GT Swap... COP TZER Turbo Performance 6 24 Jul 2003 12:34 am
