Removing The Dash/Radio Bezel On A '06 Touring
Old 01 May 2014, 04:43 pm
Send a message via Yahoo to cobras36x
Default Removing The Dash/Radio Bezel On A '06 Touring
I've seen the pictures, I can see the screws in the heating vents, but for the life of me I can't find any way to get a screw driver onto them. They appear to be covered in part by the vent shell, not allowing direct access to the screws. Any assistance at all will be appreciated, I need to swap out the power window switch because my driver's side front window is now stuck in the down position.
Thanks in Advance
John in Fuquay Varina, NC
Old 01 May 2014, 05:00 pm
Default Re: Removing The Dash/Radio Bezel On A '06 Touring
I don't have the second generation but I think you have to turn the vent like 90 degrees one way or the other to get at the screws inside.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 01 May 2014, 05:01 pm
I will try that, since I only tried one position, the one that let me see the best.
Thank you.
Old 01 May 2014, 05:12 pm
Many thanks, that was it exactly. The vent louvers are horizontal, or spin it 180 degrees if you still can't see it, to get full access.
Old 01 May 2014, 08:03 pm
Ray_Dockrey's Avatar
When I installed my stereo in my Cruiser I just left those screws out. I got tired of taking them in and out as I worked on the car each weekend.
Old 01 May 2014, 08:17 pm
Turns out I didn't need to take them out, since it's not the switch, its the junk inside the door that's decided it doesn't have to work any longer.
Old 01 May 2014, 08:42 pm
Check the wires where it comes froom the body to the door. MY 2006 Sebring
had several broken wires. Caused by the copper strands that are to thick, probably cheaper, thin wires strands would bend easier.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 01 May 2014, 09:16 pm
Thanks, I'll look at that, too.
Old 11 Jun 2014, 12:10 pm
Angry Re: Removing The Dash/Radio Bezel On A '06 Touring
have an OG that my front left window went down and is not coming up. I've read the threads and it seems,like everyone else, it must be the switch. i can get the dash moving, but it does not remove from the top. reading the posts it seems there are 2 screws by the vents? Once i do this( i hope) do you think moving the wires will allow me to get the window up until the full switch actually comes in? Thank God for the Forum. everyone else s problems and cures have been super helpful!!
Old 11 Jun 2014, 12:44 pm
LionPT's Avatar
Here is a video on replacing the stereo, it shows you how to pull the cover off.
Nexus 5X, Nexus 4, Nexus 7 (2013)
Tags
dash bezel, screw, vent
Wax for PT Dash and Bezel? Handy_Cruiser Interior Accessories Forum 13 13 Dec 2013 06:37 pm
removing the center dash bezel gcb Interior Accessories Forum 4 03 Feb 2013 08:23 pm
radio bezel atracats Interior Accessories Forum 8 04 Nov 2011 08:31 pm
Info on removing Speedometer Bezel? Retroguy Interior Accessories Forum 7 31 Mar 2011 03:12 pm
Removing Bezel Around Radio on a 2007 Superwoody Sound and Security Forum 4 03 Sep 2007 01:15 am
