Which is easier to hook up-Voltage or Oil Pressure
Old 21 Apr 2004, 06:08 pm
Default Which is easier to hook up-Voltage or Oil Pressure
Hi all.. Getting some gauges for my Pillar Pod and was wondering which would be easier to hook up... the Oil Pressure or Voltage meter?
Thanks.
Old 22 Apr 2004, 09:21 am
I would assume the voltage - almost anything electric you can tap into and get a reading. Is the oil gauge fed by tubing or is it electric? If it's electric, there should be a sending unit included. If it's tubing, be careful not to introduce and leaks...
Old 22 Apr 2004, 05:46 pm
Thanks.
behind the drivers side A-pillar there are a few wires you can use if you are using a pillar pod gauge. I THINK you can tap into the ORANGE wire for power. It will dim with the dash lights. Check with others to confirm this. Good Luck![?]
Check Engine Light came on - code 1188? coolvirus General Turbo Discussions 38 25 May 2011 09:01 am
Tranny She is a no-good! scottscars Stage Turbo Kits 15 16 Oct 2004 11:11 am
