How to remove dash or get to A/C duct?
  • 1 Post By LionPT
Old 10 Aug 2015, 08:29 pm
Question How to remove dash or get to A/C duct?
REALLY dumb question, but.... I was trying to cool/solidify a tube of chapstick that probably melted in the heat inside my car...and dropped it down the A/C vent
Is there a way to open the dash to get it out? I heard it drop down to the bottom of...wherever it goes.
Or, how can I get the tube back out? Also will it damage the engine at all? I noticed my check engine light was on the next time i turned the car on :|
2006 PT Cruiser, base model
Old 10 Aug 2015, 09:16 pm
LionPT's Avatar
Default Re: How to remove dash or get to A/C duct?
Which of the vents did you drop it down..??
The check engine light is just a coincidence, that's another problem. Most auto parts stores will read/check the code for free.
Nexus 5X, Nexus 4, Nexus 7 (2013)
Old 10 Aug 2015, 09:48 pm
Left side vent on the central dash panel. :|
Old 11 Aug 2015, 07:08 am
LionPT's Avatar
Use a flashlight to looked into the center vent...turn each vent till you see a screw at the bottom. Remove the 2 screws...one each vent if they are there...with the screws removed, grab a hold of the upper right side & pull. This should pop the holding clips, you will have to pull all the way around the center cover. Once the cover is unhooked, you will have to slide the red tab over & pull the plug from the clock. Now you can lay the center cover on it's side without having to unhook the vent controls.
Chrysler PT Cruiser 07 Stereo Removal Instructions / Sound Repair
Gkon likes this.
Old 14 Aug 2015, 04:27 am
Will that get me to the A/C duct though? I can hear it roll from side to side whenever I turn :|
Tags
a/c duct, a/c vent, dashboard, dashboard removal
How do you remove the dash top panel? eflyguy The Detail Shop 14 14 Nov 2015 06:14 pm
REMOVE top dash for 3-1/2 speaker replacement kctobyjoe Interior Accessories Forum 14 09 Feb 2014 12:15 pm
how do i remove center dash lv42day Interior Accessories Forum 21 09 Apr 2012 06:41 am
How to remove dash in a 1st gen pt Dill General PT Cruiser Discussions 8 08 Aug 2011 07:28 pm
Heater air duct cleanergmm Tech & Performance Forum 2 23 Jan 2011 07:33 pm
