Help........Can anyone tell me how to get at the antenna wire behind the radio to install a splitter so that my scanner can share the same antenna?
Thanks in advance!
Someone may sell a double connection. [:I]
Kingkole02 Just Cruisin, 03 N/A auto. TE Steel Blue w/ pearl coat & chrome package. Too many extras to list, see pics |
Thanks for the help. I have the connector, I just need to know how to get at the back of the radio and un-plug the antenna wire to use the connector. My hand is to big to get in there
and I'm looking for some kind of shortcut.Neil M.
Neil from Maine 2003 Patriot Blue PT Touring Edition |
Neil,
You are going to have to take the radio out. 1) Remove the 4 AC knobs (can be a pain) 2) pry out the window switch box (from top dead center) and disconnect switch from harness (slide red switch lock and pull harness) 3) Remove screw in trim plate behind where the window switch box used to be (up on top, dead center) 4) Carefully pry trim plate from dash 5) remove 4 screws holding in radio & pull from the dash 2002 & newer PTs use a different antenna (non-Motorola end). Make sure you get the right adapters. Scott
\"If you choose not to decide, you still have made a choice.\" |
Thanks Scott. I'll see if I can muster ther courage to do it. I have a 2003 Touring Edition.
Neil M.
It's not that hard ,just sounds that way.
04 cool vanila Limited Turbo ![]() Wife has a 03 limited (Steel Blue) |
or you can tap into where the antenna connects beside the glove box under the side panel of the sdash on the passenger side that is where i pulled my antenna cord from when i shaved mine my cruiser is an 02 toruing if that makes a difference
joshey
http://www.trialclix.com/index.asp?refID=114683 i already got an ipod for free check it out |
Thanks Joshypt.......[^]I had been trying to get up the nerve to tear the dash apart to get the radio out as ElectricBlueGT had sugested and Jimbo had encourged me to then I saw your post. I went out in the garage and dropped the panel that contains the glove compartment then the panel to the right and BINGO......
there's the cable and the connector. Wow, how easy and quick. As usual the wonderful folks on this forum pulled through with good information again.Thanks All.[^] Neil MacDonald
| XM Radio Antenna | upser14 | Sound and Security Forum | 8 | 14 May 2009 10:02 pm |
| Installing New Antenna | DestroyerMD | Exterior Accessories Forum | 1 | 11 Jun 2005 10:40 pm |
| My BTG chromed "shorty" radio antenna... | Gary04GT | Exterior Accessories Forum | 21 | 12 Mar 2004 08:52 pm |
| well theres goes my radio | JaxPT | Non-PT Discussions | 11 | 02 Mar 2004 12:13 pm |
| Radio drives me crazy!! | Alan Welch | Sound and Security Forum | 2 | 03 Feb 2004 01:44 pm |
