2003 PT Cruiser radio problem
Old 05 May 2016, 02:53 pm
Default 2003 PT Cruiser radio problem
my radio turns on and off by itself as I'm driving any any ideas? Thanks in advance
Old 05 May 2016, 02:59 pm
Default Re: 2003 PT Cruiser radio problem
if you can move the key in and out to create this. There is your problem. Another cause can be the main connected in the steering column. Try moving the tilt to affect this. Or it just might be the unit.
Old 05 May 2016, 04:34 pm
I tried both, thanks! I once read on a thread...seems like there was lavender and white wire that could be disconnected somewhere?
Old 05 May 2016, 05:09 pm
rcktpwrd's Avatar
is the radio turning off completely as in no sound or just the display going off?
If the entire radio is going off then it's probably time to replace it.
If just the display is going off then you can probably fix the issue. Like mentioned above it could be time to replace the ignition cylinder or it could be a bad ground connection in the steering column.
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS; 1989 Chevy Suburban 2500
www.rcktpwrd.com
Old 08 May 2016, 09:30 am
Yep, if you're not findng any fuse type issues again .... I rattled the column and started tapping against the key and sure enough that is the symptom! Thanks
Air conditioning problem in a 2003 PT Cruiser jbander General PT Cruiser Discussions 0 21 Apr 2014 12:26 am
2003 pt cruiser radio issue plz help cottoncandy41102 Sound and Security Forum 2 04 Mar 2013 06:26 pm
Radio out of 2003 Cruiser jbander Classifieds: For Sale/Trade 0 27 Aug 2012 01:54 pm
2003 PT Cruiser A/C problem blondjenn Tech & Performance Forum 11 07 Nov 2010 02:55 pm
2003 PT Cruiser idle problem oscar514 Tech & Performance Forum 2 13 Sep 2009 12:17 am
