Adding a 12v power outlet in center dash
Like Tree7Likes
  • 5 Post By sanatanadharma
  • 1 Post By thehoghunter
  • 1 Post By wheeluh_boy
Old 18 Aug 2016, 01:00 pm
Question Adding a 12v power outlet in center dash
Here are the stats: 05 PT cruiser, base model. 135K
Hey all, I was wondering if you could help me out with a little project.
In the attached picture, I've got circled the capped off area where a 12v power outlet/cigarette lighter port can go.
Can anyone tell me how exactly to add in such a device? What wires do I need to tap into? Does anyone have pictures or how-to that would help a would-be electrician such as myself?
Old 18 Aug 2016, 03:52 pm
rcktpwrd's Avatar
Default Re: Adding a 12v power outlet in center dash
there is a decent chance that the wire harness for the 12v outlet in already in the dash...
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS; 1989 Chevy Suburban 2500
www.rcktpwrd.com
Old 18 Aug 2016, 03:58 pm
sanatanadharma's Avatar
Because Trump
Old 19 Aug 2016, 08:26 pm
How would one "make it so"? Having the outlet be turned on with the car would be ideal for me.
Old 20 Aug 2016, 08:48 am
why not use the bottom one instead?
Pic courtesy of Crewzin...
Old 20 Aug 2016, 11:56 am
Because Trump
Old 25 Aug 2016, 09:02 am
Would I not have to remove the floor console to access that wiring? I've tried that once before but couldn't remove it.
Would using the wiring from the stereo be an option?
Old 25 Aug 2016, 09:35 am
thehoghunter's Avatar
You only need to get a 01-05 PT CRUISER Power Outlet with Cap, and replace the dummy cap with the power outlet...the wiring should be there already (was on my 2005 N/A). It's usually zip tied to another wire...find the plug, plug it into the power outlet, done! It would not require access into the floor console.
Just follow Sanatanadharma's instructions:
The pictured location is for the 12v battery-hot power outlet, not a cigarette lighter.
Acquire a power outlet.
Remove the center bezel and then the black switch panel.
You may find that the wiring w/ connector is already in place, perhaps tied to the wiring harness. The round delete is easily removed and the power outlet popped into place.
2005 N/A 5 speed manual - Booger bushings, K&N Filter, MSD spark plug wires, APC Taillights, Accra-Form Running Boards, Hubcap Mike's Spoke Hubcaps, Retrosound radio (usb1-2/aux1-2/bluetooth), Chrysler 1949 Hood Ornament, and a Flameball white pearl shift knob (which makes it go faster).
Old 25 Aug 2016, 09:46 am
Awesome! Thats the kind of answer I was looking for!
donn likes this.
No power to center dash kycoalminer General PT Cruiser Discussions 1 22 Sep 2015 04:31 pm
Removing Center Console Power Outlet moonstone Tech & Performance Forum 2 19 Dec 2011 02:49 pm
Power Outlet Always On newcruiser123 Tech & Performance Forum 1 31 Mar 2009 05:37 pm
Center console power outlet jimmirehman Interior Accessories Forum 13 02 Sep 2007 11:45 pm
Power Outlet Ed Lim General PT Cruiser Discussions 1 11 Jun 2003 09:40 am
