Steering wheel removal
  • 1 Post By Handy_Cruiser
Old 03 Apr 2017, 11:23 am
vermontpetey's Avatar
Default Steering wheel removal
I've done some searching, but cant come up with it. Does anyone have pics or a video of the steering wheel removal process for an '01 to '05 PT? I believe I need to remove the column cover and then access the screws from the back. Is this correct, and are they torx screws?
Thanks for any guidance - I'm getting ready to install my new wheel...
You're never too old to have a happy childhood..
Old 03 Apr 2017, 12:22 pm
Handy_Cruiser's Avatar
Default Re: Steering wheel removal
I've done it several times.
You have to remove the column coves. Then stand on your head and you can see two studs with pointed heads sticking through from the air bag. Those are held in place with spring clips. You have to take snap ring pliers or a large screw driver and pry the springs apart to let the stud heads pass. I like the large screw driver better. You need to be pulling out on the air bag at the same time.
Once the air bag is removed, the rest is just routine with a standard steering wheel puller. Be very careful with the clock spring. They break very easily and you can also wind or unwind them too much.
I'll try to find some photos if I have time. But that's the jest of it. Took me about an hour the first time. Last time it was fifteen minutes. Just takes practice.
Here's some of CREWZIN's images:
rckstein likes this.
Old 03 Apr 2017, 12:50 pm
Definitely different than I thought, but actually looks easier. Thanks so much!!!
Steering wheel spokes removal thimounier General PT Cruiser Discussions 6 15 Dec 2016 01:53 pm
Wheel cover removal????? PTAfterlife Wheels, Tires, Suspension 9 21 Apr 2012 07:53 pm
2006 power steering removal aceman7573 Wheels, Tires, Suspension 0 06 Mar 2011 09:22 pm
wheel skin steering wheel cover chintzgirl Interior Accessories Forum 0 23 Oct 2010 08:05 pm
Steering wheel RecruitPt Interior Accessories Forum 8 19 Jun 2010 12:14 am
