Picture of the difference aftermarket backlighting vs OEM makes!
Like Tree16Likes
  • 6 Post By brian2002utd
  • 1 Post By brian2002utd
  • 3 Post By brian2002utd
  • 4 Post By brian2002utd
  • 2 Post By soonercruiser
Old 05 Mar 2018, 12:16 am
brian2002utd's Avatar
Default Picture of the difference aftermarket backlighting vs OEM makes!
I recently purchased an 05 vert that had all the climate controll backlights out so I purchased a kit off ebay to replace the lamps. I have an 03 wagon so I am used to how they are supposed to look. Boy was I impressed when I fired up the lamps. Check out the comparison photo! Looks like I am going to have to redo my dash lamps now so everything matches!
Old 05 Mar 2018, 08:42 am
rcktpwrd's Avatar
Cool Re: Picture of the difference aftermarket backlighting vs OEM makes!
what kind of bulbs did you put in there?
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS
www.rcktpwrd.com
Old 05 Mar 2018, 04:25 pm
Default Re: Picture of the difference aftermarket backlighting vs OEM makes!
https://www.ebay.com/itm/White-AC-Cl...-/262505834738
rcktpwrd likes this.
Old 05 Mar 2018, 04:34 pm
Macgyverman1123's Avatar
I've got a bunch of blown out bulbs in my a/c cluster, I'd really like to replace them. How hard was it?
Old 07 Mar 2018, 03:44 am
Its very easy! First pull off all the climate control knobs and pry off the power window switch plate with a plastic pry tool or something similar. Disconnect the wires from the switch plate and set it aside. Behind the switch plate there is a screw, unscrew that and use the pry tool to get the trim off. It should come off pretty easy. Unscrew the two screws holding the climate control cluster so you can pull it out a bit for some room to work. Twist the 3 lamps to disengage and remove from the rear. The LEDs I got would not twist in to lock but have notches that line up with the openings. They fit very very snug so no issues with them not twisting to lock. They have polarity so after installing each bulb test to see if it comes on. If it does not then rotate 180 degrees and re install. The lower most bulb is the hardest because its in a tight spot but I was able to get it in with a bit of patience. Once you verify that they all light up just put everything back together in reverse order and you are good to go. The only down side is that the rest of the back lighting in your car will look out dated! I may end up replacing the lamps in my speedo/tach cluster so everything matches.
Old 25 Mar 2018, 06:47 pm
Just finished the instrument cluster with the same white LEDs. It makes everything look a cool blue instead of the factory dull green. Now on the the interior lighting.
Old 07 Apr 2018, 07:59 pm
soonercruiser's Avatar
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Break makes noise and it makes the rim very hot!!! legendisback Tech & Performance Forum 7 19 May 2016 08:39 pm
Different makes ptborch Wheels, Tires, Suspension 0 16 Jul 2013 10:48 am
What a difference a year makes! SantaGuy PT Cruiser Convertible Forum 7 09 Aug 2010 11:08 pm
Aftermarket Chrome Bumper Picture Request Pocket_Rocket Exterior Accessories Forum 4 05 Nov 2008 07:06 pm
