Mk1 seats into Mk2 - with heating..?
Like Tree7Likes
Old 19 Aug 2018, 02:19 am
Sinbad's Avatar
Default Mk1 seats into Mk2 - with heating..?
Got a sniff of a set of leather seats out of a Mk1 (circa 2002 as far as I can make out)
I'm fairly sure I should be able to physically straight swap them into a 2007 - but please advise if you know different
But, big BUT - does anyone know if CANBUS will accept the heating in the seats if I plug it in?
Not that bothered to be honest, but it would be nice - I'm more worried that I'd fry something
_________________________________________
'07 2.2 CRD
Old 19 Aug 2018, 04:32 pm
_PTGT03's Avatar
Default Re: Mk1 seats into Mk2 - with heating..?
theres no canbus dude in the seats. it's just a switch and they're all isolated to the controller on the seat. all you need really is to determine if there's the harness and fuse for the seats if not add it
2003 Green GT M/T, Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17, black and grey interior, oem cargo net, oem parcel shelf, oem slush mats and trunk protector, platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover, front and rear oem mud guards, lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit, 'ancor' brand engine mount replacements with urethane inserts. full body urethane bushings kit. Chrysler premium front speakers, Jenson 6x9 rears, oem mopar subwoofer, Boston Audio 4x55W amp. Panasonic head unit with bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 19 Aug 2018, 06:01 pm
rob302's Avatar
Not that I have any experience, but from posts I've seen over the years ., The airbags in the seats are normally the issue
Old 22 Aug 2018, 02:26 pm
rsrocket1's Avatar
seat replacement hell
This may be easier:
https://www.autoanything.com/seat-co...A12A231A1.aspx
FYI I know the Gen 1 rear seat belt buckle will not fit into a Gen 2 latch so make sure to keep the same latch with the seatbelt. Not sure about the front belt and latch.
I had an SRS fault which turned out to be a bad latch. I had to wait several weeks to find a junkyard that got a Gen 2 in and was able to pull the latch from it and it fixed the problem. The Gen 2 SRS recognizes that the front passenger is "using the seatbelt" when the latch is engaged. The driver is "using the seatbelt" when the seatbelt is pulled out.
Old 24 Nov 2018, 06:14 am
Sinbad's Avatar
This may be easier:
So..... returning to the fray on Gen 1's into Gen 2.......
I had a set of the leatherette covers in another car, and they were tut. They looked OK for the first couple of months and went quickly downhill from there. YMMV and all that, but I wouldn't waste money on them.
On the "seat belts won't fit" problem - which is let's face it pretty important - unless anyone knows different, it *looks at a glance* as if the Gen 2 stubs can be fitted to the Gen 1 seats - which is a lot easier than swapping the Gen 2 belts for the Gen 1s....
Anyone got any thoughts on that?
Did anyone ever solve the Great Air Bag Light Mystery...?
'07 2.2 CRD
Old 25 Nov 2018, 04:18 am
The 2006 and later PT's use the TIPM system. The power seat motors and the seat heaters both get their power from the TIPM. The TIPM may have to be 'turned on' by a dealer. There is a heated seat module located under the left front seat. My 2006 [w/o power seats] has a module under the right front seat, [air bags? last minute driving history?]
This could get complicated, but interesting.
Old 25 Nov 2018, 08:16 am
Sinbad's Avatar
Well I'm determined to give it a go, as Gen 2 leathers are like Rocking Horse poop over here, and my seats in the diesel are shot - plus, Gen 1 seats are about the most comfortable I've ever known. And I really don't like cloth seats, cos I'm a Princess
'07 2.2 CRD
Old 25 Nov 2018, 08:25 am
Sinbad's Avatar
Power seats I have, that shouldn't be a problem.
Seat heaters I don't have, but should be able "hot wire" via a fused link direct from a suitable point, possibly even direct from the battery, which is under the passenger seat in a diesel, and of course the switches are on the seats, so it should just be a matter of connecting to them - assuming any relays involved are within the seats also. If not, again - doable.
The biggy is the side airbags. Short term - I can trick the car with a resistor on those, if I need to...
chuzz likes this.
'07 2.2 CRD
Old 26 Nov 2018, 11:35 pm
rsrocket1's Avatar
I'm not sure what you mean by the "Great Air Bag Light Mystery" but my problem was solved when I replaced the front passenger set latch with one from the junkyard.
On the Gen 2 PT's the SRS thinks the driver's seat belt is being used when the belt is extended out from its retracted position but he passenger side is determined by latching the buckle into the latch which has a 2 pin electrical contact connector in it. To remove the passenger side seatbelt latch, you have to remove the seat with a Torx bit or use big channel lock pliers to loosen it which is OK when you're removing it from a junker.
Old 27 Nov 2018, 01:37 am
Sinbad's Avatar
I'll have to dig out the thread I was referencing ...
So... one could in theory short the switch in the Gen 2 latch, so the car thinks the seat belt is latched...?
'07 2.2 CRD
2001 Grey Leather seats - Tampa area (local pickup only) $100 for all seats thehoghunter Classifieds: For Sale/Trade 3 06 Dec 2016 01:35 pm
PT Over Heating Rekoj Tech & Performance Forum 16 22 Jul 2013 03:13 am
over heating pt walkowg Tech & Performance Forum 3 06 Sep 2012 08:14 pm
Over heating Cowboyfann General PT Cruiser Discussions 1 10 Jun 2009 02:43 pm
Leather Seats and Child Car Seats wengerda General PT Cruiser Discussions 3 09 Aug 2005 10:54 am
