19 Jul 2020, 07:38 pm
Re: Sealing and Deactivating SunRoof?
Originally Posted by rcalzadilla
I intend to seal with caulking and totally deactivate Sunroof.
Need to cut the wires to the Overhead Console switch which operate the Sunroof. Since the fuse for this controls radio, etc. removing fuse to insure non-operation is not a choice.
Anyone done this and can share information would be appreciated.
Thanks
I believe doing this would involve removing the roof liner panel to have access to the motors and harness, although i haven't gone this far and can't tell you what to do. There would be connectors to disconnect and no wire cutting to be done.
Once you're in this far you could remove the entire assembly, replace it with a lightweight plexiglass panel and seal with caulking.
