Adapter for strandard shift knobs
Old 01 Mar 2003, 09:29 pm
Default Adapter for strandard shift knobs
Trying to put beer tap handle on shifter. Need adapter. Where can I get one?
Old 03 Mar 2003, 11:07 am
http://www.revelenterprises.com/pt_c...hift_knobs.htm
Would this work?
Old 03 Mar 2003, 05:46 pm
[quote]
Would this work?
[This is what I needed. Cheaper than having one made. Thanks/quote]
Old 04 Mar 2003, 10:10 pm
Kustom Kruzr has one.
quote: Our new 5-Speed Knob Adapter replaces the stock shift knob and allows the use of just about ANY aftermarket threaded knob. Secure set screw attachment eliminates the need for glue. Your custom knob choices for the 5-speed are no longer limited to knobs specifically drilled for the 5-speed that must be glued onto the shaft. Use a Hurst T-Handle or a white Hurst knob w/5-speed pattern. How about a custom hardwood, leather or carbon fiber knob? The adapter can also be used with any of our threaded knobs for the automatic.
The adapter is machined from 6061-T6 billet aluminum, then polished and clear anodized for a high quality and attractive finish. It incorporates a 3/8-16 threaded stud that will accept most aftermarket shift knobs. The set screw and wrench are included for easy installation.
5-Speed Knob Adapter (Polished) ADAPT-001 $14.99
DB aka Basset Hound
Pics at: http://members4.clubphoto.com/don284358/
PT Shift Knobs PT-GF Interior Accessories Forum 5 09 Dec 2001 08:36 pm
Shift Knobs Bigem Vendors & Buyers Forum 1 06 Sep 2001 04:22 pm
