Go Back   PT Cruiser Forum > General Forums > Members PT Project
Muppet mechanic's 2001 LE.
Like Tree21Likes
  #141 (permalink)
Old 10 Jan 2018, 02:09 pm
rob302's Avatar
Default Re: Muppet mechanic's 2001 LE.
the white stuff on the oil cap is 100% normal. when oil gets up to temperature, any moisture boils out and since steam rises, you see the scary milky stuff on the cap.
i wouldn't worry about or deal with fixing anything you describe. the junk up top by the four fingers is likely power steering fluid. the reservoir and cap design is pretty crappy on PT's. mint was always leaky and greasy as well. couldn't find a good fitting cap and never really cared. if it's not leaking enough of anything to be low, just keep on chuggin'
mnahmnah likes this.
  #142 (permalink)
Old 10 Jan 2018, 02:40 pm
Originally Posted by mnahmnah View Post
I had an oil change... changing engine oil is never a bad thing Maybe I shouldn't have even had that oil change. The machine is just maybe falling apart.
I opened the oil cap and there was some white sludgy stuff on the cap and sitting just inside on the little ledge. That didn't look right. I put Seafoam in it, recommended amount, a couple weeks ago. Bad idea?
If after you drive your PT for about say....30 minutes if you check and the white stuff is still there, then it may be a concern. You have a sealed engine with a PCV system sooo......
It looks like it's got a crankcase seal blown, there's wet stuff all over under the intake manifold (is that the right name for the thing with 4 fat fingers sitting over the center?) And a wet ...sensor? The thing that sits on the drivers side of the crankcase. Has a red plastic thing on it. It's all wet with oil.
The weird thing is, all the stuff dripping under the car is pink, but none of the fluids are low!
This seems to be ATF??? Place a drop on a clean white rag and go rinse it with water see what happens.
I'm about done with this car... I am losing interest in keeping it going. It's the never ending cycle of "but I just did this work to it and invested this much on the last thing, I have to keep going."
You have a high mileage vehicle and it is a daily driver. No matter what you choose to own and drive like this you are going to need to allow for expenditure annually of about 1k-2k a year to keep it healthy and reliable.
Just be patient and take care of one problem and then move to the next. Try to outline all the issues and address the ones with the potential to leave you with a none running car.
  #143 (permalink)
Old 11 Jan 2018, 04:14 am
mnahmnah's Avatar
My commute is only 1.25 mile one way to work. It doesn't even have a chance to warm up, really. Could this be part of a bigger issue?
i.e. I start it at 5 degrees in my garage, and it stays in the cold zone or below on the gauge the whole time. Then it sits for 12 hours outside until I try to start it again at the coldest part of the morning, down to -16F.
That was the day it shrieked when I started it (frozen belts?), and the temp gauge went straight up in 5 seconds (frozen coolant in the thermostat?), and the exhaust smelled chemical-y. That was when I got real concerned. I had checked the coolant protection level, it should have been fine.
Recently it has quietly stalled out, sort of stealth-like, idling around 550 and dying. Other times it is fine. Most times it idles at 850-1000.
I don't think we can save it, but I thank you all for your input!!
2001 PT Limited Edition, 159,000 miles.
My dogs fit in the back. One of the split seats went into a dumpster in Tulsa, Oklahoma. I threw out the shelf and the arm rest unscrewed and fell off. We'll see how it survives the Upper Peninsula winter.
  #144 (permalink)
Old 15 Jan 2018, 08:31 am
mnahmnah's Avatar
Okay... Okay... I figured something out. (Someone recently said there's no bad time to get an oil change. But this last time, I think was - if not a bad time - it was the wrong place.)
I was looking for low fluids, which I didn't find. HOWEVER: The last mechanic randomly topped off fluids without asking me, and there's too much transmission fluid. Not by much, but it registers in the middle of the hot zone when it's 10 degrees in the garage and the car's been sitting all night. And it's been leaking for two months now, so it was a lot fuller before...
I was going to take it to this other place this morning, with a better reputation, to drain some out of it out and check the leak. It's snowing. It's a holiday. I'd rather keep my money. I can't decide.
The stuff has soaked through a couple cardboard boxes I stuck under it in the garage, and then there's the drip pans covered with it... How toxic is this junk? Do I put it all in a container and take it somewhere special? There's probably 12 ounces or thereabouts soaked out altogether. I could be pissed off, but whatever. "Figure in 1k or so per year in maintenance." Okay.
New with 2001 PT Lykkan Welcome New PT Cruiser Members 16 30 Jun 2012 08:30 am
is this the TPS for a 2001 PT Jesse6010 Tech & Performance Forum 5 12 May 2012 12:35 am
2001 PT moparbob Tech & Performance Forum 7 13 May 2010 10:34 pm
2001 pt flowerpot Tech & Performance Forum 6 05 Mar 2008 04:22 pm
"new" 2001 PT russ00001 Sound and Security Forum 9 22 Feb 2007 10:01 pm
