Go Back   PT Cruiser Forum > General Forums > Members PT Project
Muppet mechanic's 2001 LE.
Like Tree22Likes
  #21 (permalink)
Old 10 Jan 2013, 10:22 pm
mnahmnah's Avatar
Default Re: Muppet mechanic's 2001 LE.
Nope, you didn't miss anything "here.."
But maybe there was something else somewhere else that wasn't worth seeing. Don't worry yourself about it.
2001 PT Limited Edition, 159,000 miles.
My dogs fit in the back. One of the split seats went into a dumpster in Tulsa, Oklahoma. I threw out the shelf and the arm rest unscrewed and fell off. We'll see how it survives the Upper Peninsula winter.
  #22 (permalink)
Old 10 Jan 2013, 10:31 pm
I hope it wasn't this site. We do have a few lava rocks at this pearl convention.
  #23 (permalink)
Old 10 Jan 2013, 10:47 pm
mnahmnah's Avatar
It's a little more complex than that, but I don't want to be a downer.
  #24 (permalink)
Old 11 Jan 2013, 05:04 pm
mnahmnah's Avatar
Originally Posted by Ray_Dockrey View Post
If you have to just take the throttle body off. Its no that difficult.
That might be too much for me, I don't know a lot about this engine yet. Actually taking it off wouldn't be hard it seems like putting things back together is the hard part...
  #25 (permalink)
Old 11 Jan 2013, 05:19 pm
mnahmnah's Avatar
Today I went back under the hood to check the battery again. Last time cold and off the battery was 11.8. Today, 12.3. Running, the battery is 14.3-14.5, so using my "charging system for dummies" approach, I'm going to guess the alternator is fine, and may be some drain on the battery somewhere, since I drove it last night and it may have charged more than just running it in the driveway does? IDK.
More on the battery: When I observe it in the dark, running it with lights on, if I put the heater on just 2 notches, the headlights dim noticeably.
I've also noticed (for a long time, actually) the interior backlights for the instruments flicker slightly while driving.
Any thoughts on this? What is this about, if the battery and alternator are okay?
MY ANSWER (after hours and hours of forum reading in the tech library)..... DO THE BIG 3!
Idling condition:
Park and Neutral are the least shaky.
Drive and Reverse are the worst.
In reverse, it just rattles and shakes more. But in drive, it actually tries to lurch hard forward. Each time I put it back in drive it did that.
(This has since resolved iself - ? Still a little bump getting between drive and park, or, neutral and park.)
There is some water coming out the exhaust pipe (kind of spurting now and then) and made a puddle about 1/4 cup on the ground. I didn't run the engine more than 3-5 minutes. I don't see any color to it or notice any smell when I took a rag to it and smelled the rag. Is this normal?
  #26 (permalink)
Old 11 Jan 2013, 07:31 pm
mnahmnah's Avatar
Originally Posted by Busted_PT View Post
It's the other side of the filter that gets dirty first. That bolt looks like it has green paint. If so not from the heat shield. Check in the hole to see if bolt is broken off. Not something to worry with if it doesn't rattle.
Forgot to respond. It's not green paint - it actually looks black but not like paint. Just another mystery, and it's last on the list right now.
I'd like to try and take pics of the shocks next. The whole suspension system is so bad, when I took ownership of it in 09 I got nauseous going down the freeway, until I got used to it. It bobs around soo much.
  #27 (permalink)
Old 12 Jan 2013, 04:20 am
mnahmnah's Avatar
Who wants a Matchbox car of a 2001 Gold PT? Only 5 hours left (until it's relisted...)
2002 Johnny Lightning Classic Gold 2001 PT Cruiser | eBay
  #28 (permalink)
Old 13 Jan 2013, 07:29 am
mnahmnah's Avatar
NO Dexron for transmission fluid! Ok, I get the message... after I had it done last week and didn't ask.... Will call Monday.
Nope, they used ATF or at least it says so on the receipt. It however didn't state ATF+4, which also worries me. Unlicensed ATF brands can also harm the engine... Why do so many things harm this engine???
  #29 (permalink)
Old 15 Jan 2013, 05:26 am
mnahmnah's Avatar
Sorry for no pictures or updates. I'm semi-seriously considering replacing every part I'm suspicious of, and just getting it over with. So right now that would be fuel pump, intake air control valve, throttle position sensor, and throw in a few more sensors for good measure. Maybe some fuel injectors. Ha ha.
Then I have stopped worrying about the ABS light and Trac light. Forget that for now, but cleaning the speed sensors isn't a bad idea, if I can get under the car.
I just bought a "Factory Service Repair Workshop Manual" for my 2001 off ebay for 8 bucks. I'll see what I can do with it.
I also want to buy this dash cover for 90 bucks but I think I'll wait till there's one at my local pick n pull. The money must be saved for parts and tools. Aaaand,..... the expensive gas.
  #30 (permalink)
Old 15 Jan 2013, 06:00 am
Then I have stopped worrying about the ABS light and Trac light. Why? The idiots at the tire store sold me the wrong size tires in the rear, so the lights are going to probably be on from that anyway. Forget that for now, but cleaning the speed sensors isn't a bad idea, if I can get under the car.
Nope. Many folks put different size tires front/rear and don't get ABS light.
New with 2001 PT Lykkan Welcome New PT Cruiser Members 16 30 Jun 2012 07:30 am
is this the TPS for a 2001 PT Jesse6010 Tech & Performance Forum 5 11 May 2012 11:35 pm
2001 PT moparbob Tech & Performance Forum 7 13 May 2010 09:34 pm
2001 pt flowerpot Tech & Performance Forum 6 05 Mar 2008 04:22 pm
"new" 2001 PT russ00001 Sound and Security Forum 9 22 Feb 2007 10:01 pm
