Go Back   PT Cruiser Forum > General Forums > Members PT Project
NitroPT manifold madness
Like Tree63Likes
  #61 (permalink)
Old 08 Jan 2017, 06:09 pm
rob302's Avatar
Default Re: NitroPT manifold madness
Originally Posted by Dazzaman View Post
I got up to page 28 and I think it went to over 100 pages but when I came back tonight to carry on it is only showing 6 pages ?
Am I missing something ? maybe apart from my marbles
Regards Dazza.
you're confusing his manifold thread with his whole car thread.
click here: Nitro's PT Cruiser
NitroPT and Dazzaman like this.
  #62 (permalink)
Old 08 Jan 2017, 06:19 pm
Dazzaman's Avatar
AH Thank you very much for that I can now continue with my read.
rob302 you are a gentleman
  #63 (permalink)
Old 12 Jan 2017, 11:09 am
Since you polished the exhaust manifold and turbo, did you leave off the exhaust heat shield?
**2005 PT Cruiser Touring Convertible Turbo - 20x8" Milani Wheels 245/35 & 225/30, air ride & more.
Build Thread: http://www.ptcruiserlinks.com/forum/...ser-turbo.html
**2008 PT Cruiser
**2007 Chevy HHR LS - Transition to LT - 18" Solstice Wheels 235/45 & 225/45
  #64 (permalink)
Old 12 Jan 2017, 11:21 am
I will not need a heat shields for the finish project per se.
  #65 (permalink)
Old 12 Jan 2017, 12:21 pm
Handy_Cruiser's Avatar
Just put the cotton-picking thing on your car!
It's pretty and all but we want some actual performance results.
rcktpwrd and wingman55 like this.
  #66 (permalink)
Old 12 Jan 2017, 10:09 pm
Since your post of the completed product dates back to Jan. 2015, the question isn't what you "can" do. The question: Did you reinstall the heat shield? Or, has the exhaust/turbo not been installed?
A small detail about exhaust manifolds and turbo's mounted in the rear compartment, would be they are nearly unnoticeable. The opposite applies to engines with front mount exhaust.
**2008 PT Cruiser
  #67 (permalink)
Old 12 Jan 2017, 10:18 pm
The factory heat shield basically protects the coolant reservoir.
If you relocate with an upgraded recovery tank then the aluminum OEM heat shield really serves very little benefit.
  #68 (permalink)
Old 12 Jan 2017, 10:36 pm
I'll assume you replaced it. What's the storage capacity of the factory reservoir?
**2008 PT Cruiser
  #69 (permalink)
Old 12 Jan 2017, 10:47 pm
I don't usually quote...when responding to question but..
It really does not matter so much. I would at least use something universal aluminum and from say a company like Be Kool.
In reality if you plan your cooling system and temperature control correctly you should only need a very small tank.
I have a 1.6 SuperCharged MINI with a rather high HP and TQ output and use a very simple Be Kool universal tank that has worked well since about 2004. It may hold 8 to 12 oz of fluid? The tank mounted inches from the OBX header.
On the PT I would think about a tank closer to the outlet port of the thermostat housing and just getting it completely away form the Turbofold.
Here is something to think about. Heat shields are to protect components around a high heat generated part but the negative effect is that that part generating the heat also retains the heat and in some circumstance through heat soak increases the heat of the part in the first place. Better to relocate parts that could be effected by heat and let the heat generating part have some air space to cool off.
  #70 (permalink)
Old 12 Jan 2017, 11:35 pm
I definitely agree to this point.
Thanks for the details.
**2008 PT Cruiser
Motor Mount Madness!!!!! VetteJohn General PT Cruiser Discussions 4 16 Dec 2014 07:37 pm
Motor Mount MADNESS!!!! Look at this!! RacerX125 Tech & Performance Forum 7 12 Sep 2014 10:12 pm
March Madness Giveaway Contest! skylight General PT Cruiser Discussions 38 17 Mar 2004 11:26 pm
