Go Back   PT Cruiser Forum > General Forums > Members PT Project
Project El Cheepo v2.4
Like Tree255Likes
  #541 (permalink)
Old 26 May 2018, 09:49 pm
SPLNeon's Avatar
Default Re: Project El Cheepo v2.4
Nitrous fogger nozzle installed, 41N 18F
Throttle cable somewhat figured out. I do not like the angle of the cable, but its functional for now.
Carnut likes this.
THE UNDISPUTED KING OF THE PARKING LOT
Competition's paying the price.
03 PT GT. DSI canned tune, Weight redux, MH Racemaster Slicks/Rota Slipstream 15" 11.95 at 118.41mph 1/4 mile
96 SOHC Neon Turbo
08 CSRT4. Realtune MS1K v1 pcm stg0 NSRT4 Injectors.
  #542 (permalink)
Old 01 Jun 2018, 06:58 pm
SPLNeon's Avatar
Boost leak testing done today. Found a major leak on the hotside charge pipe right at the intercooler. I never checked for leaks last year when I put the stock intercooler back in so I'm guessing it has leaked since then. Leak also at the fuel side flare on the fogger nozzle. And one other bad clamp.
Ready for June 8th. Praying that I don't get rained out again.
96 SOHC Neon Turbo
  #543 (permalink)
Old 10 Jun 2018, 11:50 am
SPLNeon's Avatar
Took it to the track Friday night. Kept blowing off the charge pipe. Didn't get a clean pass. Also found out the throttle spring is way too stiff for drag racing. Ran 12.6's with no boost and nitrous only lol
rob302 likes this.
96 SOHC Neon Turbo
  #544 (permalink)
Old 10 Jun 2018, 03:14 pm
rob302's Avatar
i saw the pic of the pipe that kept blowing off was coming off an elbow that was just smooth at the end. if it were mine, i would scuff it with rough sand paper and then "flange it" a bit with a pliers.. or stick a couple sheet metal screws in it... or both
12.6 with no turbo. LMAO hope to see a new record best in your future with your upgraded intake.
when the pipe popped off, did you immediately think the JB weld failed?
can you wind the TB spring tighter and eliminate the one you added?
  #545 (permalink)
Old 10 Jun 2018, 06:26 pm
rcktpwrd's Avatar
Cool Re: Project El Cheepo v2.4
pipe bead roller....
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS; 1989 Chevy Suburban 2500
www.rcktpwrd.com
  #546 (permalink)
Old 11 Jun 2018, 11:03 am
SPLNeon's Avatar
I ended up eliminating one of the connections. Used goop as well for adhesive. The worst part now is the heat from the turbo radiating up to the charge piping and couplers. I may have to make an aluminum heat shield under the piping. Good to know about the throttle body spring. I'm thinking it may be the angle of the cable that's messing up full closure without the help of an external spring. I put a softer on in and it seems way better now. But won't knowuntil rolling into the beams in boost
96 SOHC Neon Turbo
  #547 (permalink)
Old 11 Jun 2018, 11:05 am
SPLNeon's Avatar
Originally Posted by rcktpwrd View Post
Thanks for the link 👍
rcktpwrd likes this.
96 SOHC Neon Turbo
  #548 (permalink)
Old Yesterday, 10:05 pm
SPLNeon's Avatar
Blew the ghetto intake apart on the second run.
Noticed weather cracked on the piece I used from the stock soft charge pipe too
96 SOHC Neon Turbo
Project #363 767skyking Members PT Project 115 29 Apr 2015 11:45 am
New project ptgrotje Members PT Project 23 21 Aug 2013 01:32 am
Well on to the next project: Candyman The Detail Shop 4 24 Aug 2011 10:35 pm
New Project Car :) HAPPYDADDY76 General PT Cruiser Discussions 7 29 Jul 2008 05:00 pm
New PT Project Deathstar Exterior Accessories Forum 9 09 Apr 2008 06:59 pm
