Go Back   PT Cruiser Forum > General Forums > Members PT Project
Something Very Different
Like Tree17Likes
  #11 (permalink)
Old 07 May 2017, 01:29 am
Default Re: Something Very Different
The reason I'm removing these things is partly because I think I have damaged my power steering by removing the hoses that connected to it, and the A/C I depressurized the whole system by accident and probably destroyed that as well, and I don't want to spend extra money fixing those things if I don't really need it.
  #12 (permalink)
Old 10 Jul 2017, 11:10 am
rob302's Avatar
any updates on this??
  #13 (permalink)
Old 10 Jul 2017, 01:46 pm
Gkon's Avatar
I'm digging it!
2002 PT Cruiser Limited, 2.4L, Automatic Transmission, Metallic Silver Paint
  #14 (permalink)
Old 10 Jul 2017, 03:22 pm
Turbodude06's Avatar
This is my kinda build!!! Keep it up!!
Gkon likes this.
2004 PT GT 5-Speed! Project "THE RIDDLER"!!!
http://www.ptcruiserlinks.com/forum/...t-5-speed.html
  #15 (permalink)
Old 10 Jul 2017, 10:43 pm
I'm sorry everybody, I got a job about a month and a half ago and i've been busy working on it and making money. Big update!
FMIC (Pain in the butt because Im using normal PT bumper)
GT Wheels plasti-dip black.
I also got the wiring harness, still need a lot more. I need a transmission (either a Getrag 288 or a NVT350), ECU (preferably High Output), CV Axles, motor mounts, fluids, and lowering springs and front struts. I also have to replace some of the seals/gaskets on the engine and do my timing.
VsandFords and rob302 like this.
  #16 (permalink)
Old 11 Jul 2017, 08:56 am
svtnos's Avatar
so is this a turbo car or na??
2003 PT Cruiser limited edition
  #17 (permalink)
Old 13 Jul 2017, 02:40 pm
It was an 01 N/A automatic and I'm swapping it to a turbo manual.
To get it low I used autozone helper springs. The spring rate on those were perfect for this.
  #18 (permalink)
Old 26 Sep 2017, 01:16 am
She's nearly done. Only problem now is that she won't start. No spark coming from the coils for some reason. Probably a bad crank position sensor. But no check engine light code for that. What other things could be stopping spark? She was driving around a week ago. Also need to get beefier axles and a better clutch. Stock used neon clutch is holding up surprisingly well. So far it has a mopar blow off plate, stage 1 injectors, and soon will have an AGP aftermarket wastegate. Many many more planned mods.
Needs new wheels. Badly. Also want to paint my car white instead of taupe frost. That paired with black GT or Prowler front wheels would look amazing.
Handy_Cruiser likes this.
  #19 (permalink)
Old 26 Sep 2017, 08:19 am
rob302's Avatar
Originally Posted by kcabe1 View Post
problem now is that she won't start. No spark coming from the coils for some reason. Probably a bad crank position sensor. But no check engine light code for that. What other things could be stopping spark? She was driving around a week ago..
i would think that your wiring and tinkering are the no-spark issue and would be best if you looked over what you've done since it last ran. IMO there's no reason a crank sensor would just decide to fail while parked. these are the hardest problems to advise a fix for. only you really know what you've touched in this case, what you've soldered, taped, tugged on, etc.
