Go Back   PT Cruiser Forum > General Forums > Members PT Project
My "Special" spare tire.
Like Tree65Likes
  #11 (permalink)
Old 26 May 2017, 09:51 am
VsandFords's Avatar
Default Re: My "Special" spare tire.
[IMG][/IMG]
When I started this, I thought about stripping the paint.
[IMG][/IMG]
This didn't work so well. That is when I switch to using these.
[IMG][/IMG]
Yesterday evening I sanded the outer bead part of the rim and am attempting to get ALL of the paint out of the small areas in the middle around the lugs.
vermontpetey and Carnut like this.
  #12 (permalink)
Old 26 May 2017, 10:10 am
The lip is an easy fix with a piece of wood (short 2x4) and a hammer. Light but firm taps on the wood against the lip should round it up nicely.
VsandFords likes this.
  #13 (permalink)
VsandFords's Avatar
Originally Posted by rob302 View Post
OK Rob, I gotta know, what is going on here? I can see your cutting the tire, WHY????
  #14 (permalink)
Old 26 May 2017, 11:11 am
VsandFords's Avatar
I didn't mention and didn't take a before picture. I have been working the lip since the beginning. It was a lot worse than seen in this picture. Been having to use hard firm "taps", the lip is being fairly stubborn.
[IMG][/IMG]
[IMG][/IMG]
Hopefully you can notice a difference between these two pictures.
  #15 (permalink)
Old 26 May 2017, 11:56 am
auuuuh..... yes I can. Part of your difficultly is the tire still mount on the rim acts as somewhat as support to the lips integrity. Maybe if you pull the tire you can cosmetically succeed?
ptprice and VsandFords like this.
  #16 (permalink)
Old 27 May 2017, 07:53 am
VsandFords's Avatar
[IMG][/IMG]
Yesterdays progress. Started sanding with 280 paper.
  #17 (permalink)
Old 27 May 2017, 08:03 pm
VsandFords's Avatar
[IMG][/IMG]
The rim is almost trued up. NitroPT was on the right track, I took out the valve core and made a big difference in resistance. Changed from a piece of 2x4 to a 2 inch diameter dried oak branch. I am now focusing on the out rim. You can see all of the tool marks while forming.
More sanding.
NitroPT and ptprice like this.
  #18 (permalink)
Old 28 May 2017, 04:24 pm
VsandFords's Avatar
[IMG][/IMG]
More sanding today. Up to 320 grit.
[IMG][/IMG]
These are some of the things used in the process. Wrapped and taped some sandpaper to a 5/16 rod to get rid of the tooling marks on the outer lip.
[IMG][/IMG]
moved to 500 grit.
Because this is a street car, I am stopping at 500 and not going to 1000 or 1200 grit for a "mirror" finish.
Carnut likes this.
  #19 (permalink)
Old 28 May 2017, 04:33 pm
VsandFords's Avatar
Color me DONE!
[IMG][/IMG]
Hand polished with Mother's brand aluminum polish.
[IMG][/IMG]
Start
[IMG][/IMG]
Finish.
Polished twice, washed, waxed with Meguiar's synthetic wax and Eagle One tire shine. Ready to remount on Cruiser and hide from site.
[IMG][/IMG]
Next?
  #20 (permalink)
Old 29 May 2017, 03:00 pm
VsandFords's Avatar
[IMG][/IMG]
This is the reflection with 500 grit. Not a "mirror" finish, but not bad.
[IMG][/IMG]
Mounted and ready for the next flat. It's now the prettiest, cleanest thing under the Cruiser.
The "Handy" NOPI Strut Bar Install: Part "Deux" (2) Handy_Cruiser Tech & Performance Forum 2 01 Aug 2015 10:37 pm
"Donut" spare tire DonGee General PT Cruiser Discussions 16 18 Jan 2015 11:37 am
Turbo "phhsssss" or "whoosh" sound--Normal? Silenceable? Help! Memark General Turbo Discussions 13 24 Nov 2010 10:56 pm
Tire size for staggered 20" Rear 18" Front ???? dpolley Wheels, Tires, Suspension 4 10 May 2009 09:54 pm
