Go Back   PT Cruiser Forum > General Forums > Members PT Project
Auto shifter modification
Like Tree37Likes
Old 25 Jun 2017, 05:29 pm
VsandFords's Avatar
Default Auto shifter modification
I always thought it would be COOL to have a TALL shifter like you see in old hot rods/rat rods. I built one using things I had in the shop.
[IMG][/IMG]
Simple. I used a piece of 1/2" electrical conduit, 1/4" brake line, PT shift knob and two 8/32 machine screws.
[IMG][/IMG]
I drilled two 9/64" holes in one end of the conduit and tapped them with a 8/32" machine tap to mount the set screws to attach the new shifter handle to the shifter shaft coming out of the console.
[IMG][/IMG]
I used the die grinder with a ream bit to enlarge the hole in the shift knob so the conduit would slide in.
[IMG][/IMG]
I drilled a hole in the top of the new stick for the set screw to mount the PT shift knob.
[IMG][/IMG]
The brake line goes inside so when you push the button, you are able to move the shifter.
Last, I sanded the conduit starting with 180 grit sandpaper and finishing with 500 grit to give it the polished look. Clear coated it because it is metal and didn't want it to tarnish.
[IMG][/IMG]
This also works with the "cobra" shifter. Start by cutting off the plastic sleeve.
[IMG][/IMG]
Use the die grinder and ream the handle so the conduit will fit.
[IMG][/IMG]
Someone that is good with leather could make a sheath to cover the stick.
There you have it. Easy-peasy!!!
Old 25 Jun 2017, 05:32 pm
Default Re: Auto shifter modification
That's way RAT ROD at its finest!
You are a HOT ROD FREAK!!!
Busted_PT and VsandFords like this.
Old 25 Jun 2017, 05:39 pm
VsandFords's Avatar
The GREAT thing is that you can make them any length you like. I also built a cobra shifter at stereo height. You can swap them out in less than a minute if you have the tools for the set screws close.
Gkon likes this.
Old 25 Jun 2017, 05:42 pm
I believe you have done the first on a PT. I have yet to see another in all the pic I've seen. 😎 Like that you kept it cheap to do. 😊
VsandFords likes this.
Old 25 Jun 2017, 06:30 pm
VsandFords's Avatar
Also noticed a milestone. This thread was my 1000th post!!!!!
Old 25 Jun 2017, 06:58 pm
rckstein's Avatar
'06 Touring Edition NA Automatic
160k Miles / Electric Blue Pearl
USMC '82 - '93
Old 25 Jun 2017, 08:28 pm
Handy_Cruiser's Avatar
That is so SUPER COOL!!!!
I don't think I've ever seen that done before.
Old 25 Jun 2017, 08:39 pm
rckstein's Avatar
Carnut is always posting about hot rod stuff, I could see him doing this mod to his 'vert
USMC '82 - '93
Old 26 Jun 2017, 01:37 pm
vermontpetey's Avatar
This is SUPER COOL - would look great in my 'vert with the shift ball painted teal to match my dash.
Damn, I'm never gonna get this car done...lol
rcktpwrd and VsandFords like this.
You're never too old to have a happy childhood..
Old 26 Jun 2017, 03:31 pm
Carnut's Avatar
Yep, pretty cool idea.
Although for the life of me I can't understand why anyone would want to make an 'Old Skool Hot Rod' out of a PT Cruiser.
George H. McDowell
Wichita, Kansas
mailto:carnut@carnut.com
http://www.carnut.com/
FB https://www.facebook.com/george.c.mcdowell
My 2005 PT Cruiser GT Convertible Project
Modification of stock Automatic Shifter Handle? Gkon Interior Accessories Forum 9 09 Nov 2015 08:20 am
06 auto shifter/cable oldschoolpt Classifieds: Want To Buy 0 22 Jan 2013 06:33 pm
Auto Shifter shaft WolfmanG Interior Accessories Forum 6 10 Jun 2011 11:13 pm
PT A/S Auto Transmission Shifter bmeador55 General PT Cruiser Discussions 0 09 Aug 2010 05:41 pm
Auto Shifter Kit and NOS vs. Turbo milPT Tech & Performance Forum 9 27 Feb 2004 09:18 pm
