Custom Wheels
Go Back   PT Cruiser Forum > Regional Forums > Midwest PT Forum
fuse box diagram
Closed Thread
Old 20 Feb 2010, 07:54 pm
Default fuse box diagram
Does anyone have a diagram of the fuse box thats under the hood of a 2001 Pt Cruiser? Brake lights and tail lights are out and the fuse in the inside bos is good and the bulbs are all good too. Wondering if theres another fuse related to these lights. Thank you!
Old 20 Feb 2010, 09:00 pm
Taggert_LOA's Avatar
Send a message via AIM to Taggert_LOA
Default Re: fuse box diagram
it's your brake light switch under the pedal. replace it. problem solved.
"Every civilization finds it necessary to negotiate comprimises with it's own Values"
Old 21 Feb 2010, 06:50 am
Just in case it's not the switch, the No#12 fuse under the hood is for "Stop Lights".
2000 PT. Original Owner, 115,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
NY Times article: http://www.nytimes.com/2008/10/30/au...30vintage.html
Old 21 Feb 2010, 04:37 pm
Thank you both. It was the fuse under the hood...problem solved
Old 06 Sep 2010, 04:20 pm
Your replacing the whole fuse box ???
Don't think there's anyone with the diagram to re-wire the whole thing. But if there is, hopefully he or she will see your post and help you.
Old 09 Jun 2012, 03:46 pm
this is the fuse box i have in my 06 cruiser. where are the relays??????
Old 09 Jun 2012, 04:04 pm
Do you have the owners manual to tell you what all the components are in your fuse box? Some of them are relays, some fuses. Other relays are in the engine compartment, on the fan shroud and by the firewall on the drivers side.
Your owners manual (which you should have) tells you what is what with all the bright colored components in the IPM (Integrated Power Module).
Closed Thread
no Fuse problem and not iod fuse ptcarter Tech & Performance Forum 22 13 Jan 2013 09:22 am
PCM wiring diagram PTcruzer02 Tech & Performance Forum 0 10 Nov 2009 08:35 am
need vacume diagram for turbo banlenterprises General Turbo Discussions 1 12 Sep 2008 03:32 pm
Vacuum Line Diagram turbokidd Turbo Performance 1 17 Sep 2007 11:55 am
Need Diagram KingKole02 Tech & Performance Forum 5 24 Jan 2006 08:09 am
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
