Go Back   PT Cruiser Forum > Regional Forums > Midwest PT Forum
white smoke
Old 07 Aug 2012, 08:11 pm
Default white smoke
So changed my oil now its haveing a hard time to get going and now it spewed white smoke dont know whats going on and i hope someone does plz let me know asap
Old 07 Aug 2012, 08:24 pm
Default Re: white smoke
Is that white smoke out the tailpipe? If it is, that's what happens when oil gets into the combustion system. Not good.
A blown head gasket would allow oil to get into 1 or 2 of the cylinders and cause white smoke and you'd loose power from either or both of those cylinders. Engine making less power would need higher revs to get going. Still would have almost nothing to do with changing the oil. Maybe a coincidence?
P.S. Please don't start a new thread every time you have a question on the same things that's happening. Just add another post to the on-going thread.
Old 07 Aug 2012, 09:10 pm
How much does that usually cost to fix
Old 07 Aug 2012, 09:28 pm
You can't think of cost till you find out what the problem is.
Old 07 Aug 2012, 09:33 pm
Is the white smoke coming out the tail pipe or did you spill oil on the engine engines electrical (namely coil or wires) and exhaust manifold.
Its odd that you problem started only after changing the oil?
lot of this lately?
Old 07 Aug 2012, 09:34 pm
Kawizx9r's Avatar
Few questions;
1. Where are you located? Update your signature; sometimes a member will offer help if they're local to you.
2. Any engine codes?
3. To better help you figure out what's going on, you should provide information for questions asked such as 'is the white smoke coming from your tailpipe?'
For us to help you, you need to help us. Organize your thoughts, educate yourself with what you're reading here/wherever, and provide us some info on the situation.
NitroPT likes this.
Kawi is a friggin genius!
Old 07 Aug 2012, 09:37 pm
I dont know if i spilled any oil but it doesnt make any sense why the is power loss and takes it so long to go when accelerating and produceing white smoke when accelerating
Old 07 Aug 2012, 09:38 pm
Ok and it is coming out the tailpipe
Old 07 Aug 2012, 09:40 pm
Kawizx9r's Avatar
Check your coolant, are you running low?
Pull your oil dipstick tube; is it milky at all?
Old 07 Aug 2012, 09:45 pm
No coolant is fine and no its the appropriate color and theres both mixed in with it
White Smoke from Exhaust susiegtx General Turbo Discussions 8 14 Dec 2011 06:08 pm
GT Turbo: Blue White Smoke Valve Seals popeye304 Tech & Performance Forum 4 24 Jul 2011 05:54 pm
Loss of Power - White Steam/Smoke from tail Pipe jaa70 Tech & Performance Forum 16 04 Dec 2010 02:19 am
Strange Noise from engine and white smoke draven4099 Tech & Performance Forum 7 08 Jun 2009 01:05 pm
Car over Heated white smoke knocking noise dying Ctown General PT Cruiser Discussions 26 28 Apr 2009 06:03 pm
