Go Back   PT Cruiser Forum > Regional Forums > Midwest PT Forum
2005 PT Cruiser 2.4 LE ECU files
Old 11 May 2016, 01:45 pm
Default 2005 PT Cruiser 2.4 LE ECU files
Hello all im in need of some pt cruiser tuning/remapping files, if anyone can help that would be exelent. Problem is both o2 sensors have low volts 31-37 codes
Old 11 May 2016, 02:23 pm
Fk5 Fk5 is offline
Default Re: 2005 PT Cruiser 2.4 LE ECU files
Why do you think remapping will help? I wouldn't screw with the maps until I got rid of the CEL. Was there some mod that predicated your codes? Exhaust change perhaps? Dump the cats?
2003 GT 5 speed
162,000 miles
Old 11 May 2016, 03:17 pm
Light came on and gave 31/37 and i replaced both o2 sensors thats all that was done, and cleared the 31/37 codes and those 2 codes constantly come back.
Old 11 May 2016, 03:39 pm
Fk5 Fk5 is offline
I don't think the ECU is your problem and if it is, I am not sure files or a remap will help. I think those codes are for how quickly they heat up. Look at the connectors. Look at all the wiring, particularly the grounds. Some new sensors are bad out of the box. I have read that some Bosch sensors have a different warmup parameter than can cause them to code. An exhaust leak could keep them from warming up fast enough., etc.
2003 GT 5 speed
162,000 miles
Old 11 May 2016, 03:40 pm
SPLNeon's Avatar
I would trace both the o2 sensor wiring to see if it is rubbed through somewhere. If good, check and clean all the grounds under the hood. Of that fails to solve the problem, you may have to get a reputable dealership to check the ecu.
Fastest fwd PT Cruiser in Canada
Competition's paying the price.
03 PT GT. DSI canned tune, Weight redux, MH Racemaster Slicks/Rota Slipstream 15" 11.72at 116mph 1/4 mile
96 SOHC Neon Turbo
08 CSRT4. Realtune MS1K v1 pcm stg0 NSRT4 Injectors.
Old 11 May 2016, 04:12 pm
You can turn them off if you have a DiabloSport product.
To turn them off at the stock PCM you would need an PCM file access device like what Chrysler used called the *"Iintegrator". The *only surviving known one left is owned by Keven @ SykedTuning. They also can turn off your H02s as well but you would need to send your PCM to them.
http://sykedecutuning.com/store/index.php
Old 11 May 2016, 04:26 pm
Handy_Cruiser's Avatar
Even if you have a Diablosport Trinity or Intune, you will need someone with CMR or similar software to do a custom tune in order to disable the O2's. I don't know if older Predator U7134 for the 2.4 turbo had that capability or not. The older (un-updated) U7135 for the Hemi engine does. I have one.
Around 2010, someone at the Fed got after tuner manufacturers here in the US and some of them (not all) dropped the ability to disable emissions-related items from their software. Diablosport dropped them. But again, someone with the right custom tuning software can alter a tune to do this that can be loaded with a Diablosport handheld device. There's other ways to do this. But that's the deal with the Trinity and Intune.
PS: NitroPT, don't you have this software? I thought you did.
Old 11 May 2016, 04:54 pm
No actually you can do it..
This is where some member's really need to spend hours practicing on their personal DS device and getting to know the people on a first name basis at DS. Or at least join the DS forum and help members and also learn lots of good information about the DS line of ECU/EFI/PCM devices. You would be very surprised how much you can do that is not in the manual/CD
Never the less I think this member is not wording what is really wanted.
The first response implies PCM/ECU/EFI calibration file sharing. This means that the OP may have another platform that this can be done among users of a device and shared program.
If it were not for that I would not have responded in this thread.
What I have is not an authorized original version of a CMR and the software.. So not to infringe on copy rights of a business that I talk to often I only use it for my own personal use.
I am not sure where the information about the the Federal Government imposing restriction with Computer calibration device manufacturing companies came from. I use 3 different companies and none ever needed to make changes or eliminated access to area of emission controls. *DiabloSport was one that did not here is why. If this was the case you would not be able to make even simple fueling or timing adjustments or re scale injectors which is one of the most common practices when upgrading engine output installing larger fuel injectors. As one of many examples I could give.
Technically speaking in any State you are not suppose to change any running aspect of the engine or drive-train which could effect or change the OE standard emission output in any way. So even in states where some have no State required emission testing the Federal guidelines state other wise. And we all know the Feds will always win if challenged.
If a member would care to PM (ONLY) this information about the 2010 guidelines set by the Federal Government I would be interested to read it.
*I just wanted to add that the 93 tune that comes standard in the DS devise supported, turns off the post H02/02 sensor.
Anyone that can access the OBDII dignostic connector can see post 02 N/A
New to Us 2005 Cruiser - Help!! Alynn Tech & Performance Forum 10 31 May 2015 06:13 pm
Refurbished 2005 PT CRuiser Dream Cruiser Series 4 Convertible soonercruiser craigslist 4 13 Mar 2015 04:10 pm
2005 pt cruiser tbone6675 Tech & Performance Forum 6 12 Sep 2014 08:11 pm
2005 Cruiser sancapwork Tech & Performance Forum 10 21 Jul 2014 12:48 pm
2005 PT Cruiser TCM adstatus Tech & Performance Forum 2 16 Aug 2013 12:06 pm
