Go Back   PT Cruiser Forum > Regional Forums > Midwest PT Forum
2002 Pt limited non turbo wont start
Old 18 May 2017, 07:56 pm
Exclamation 2002 Pt limited non turbo wont start
Turn the key and the injectors and the ASD relay and the injector relay click very fast and will not stop clicking even if I remove the key. The starter is good as I ran a remote start wire between the solenoid and battery and it turns over fine.
I have checked all of the fuses twice and they are all good.
I swapped relays for known good relays and it acts the same exact way.
There is a round red LED blinking at a slow on off tempo.
I need the get this running ASAP so I can work.
Now it has had this clicking problem for almost a week but usually a few times turning it on and off it would start.
But now nothing.
Any help is HUGELY appreciated.
So thank you in advance.
Old 18 May 2017, 08:24 pm
Default Re: 2002 Pt limited non turbo wont start
The round red LED blinking slowly is the security light and means the system is armed. Does it go off when you turn the key? Do you have another key to try?
Old 18 May 2017, 09:10 pm
But now nothing.
What relays have you checked so far?
Old 19 May 2017, 08:50 am
VsandFords's Avatar
Welcome to the forum from Texas.
Please go to the new members section and introduce yourself. Tell us some good things about your Cruiser and maybe add a pic.
Old 19 May 2017, 09:52 am
No I do not have another key to try unfortunately.
Is there any way to disable skim?
And even the clicking from the relay does not stop after the key is removed.
Sorry about the late reply I had a rough day due to car and headache.
Old 19 May 2017, 09:56 am
I have checked both the ASD and the fuel injector relay .
I swapped many of them with the other known working ones.
The odd thing is when I turn the key back and pull the key out it still keeps clicking.
Its not the solenoid it is the relays and fuel injectors.
Before when it started happening I could wiggle the power panel and sometimes remove and replace the relays and It would fire right back up. But now she is stubborn as a mule.
Old 19 May 2017, 10:07 am
Old 19 May 2017, 10:22 am
Your PCM might have a relay driver that is shorted out.
You will need to check the voltage from the PCM to the ASD relay and you might see a spike in the voltage from the PCM to the ASD relay when it is clicking. Another member has it jump about 1 volt when it happens.
Old 22 May 2017, 03:56 pm
I will check that as well. I am having fits with this car 🚗
Tags
pt cruiser 2002 no start
2002 pt cruiser wont start ale_05 Welcome New PT Cruiser Members 2 13 May 2014 09:30 pm
2005 non turbo overheated wont start tjschultz81 Tech & Performance Forum 7 02 Jan 2013 10:38 pm
2002 engine cranks good wont start N2ROW Tech & Performance Forum 10 19 Dec 2011 11:31 pm
2002 PT wont start TampabayCruiser Tech & Performance Forum 6 10 May 2011 05:41 am
2002 PT Crusier showing 4 codes and wont start mattbuddah81 Tech & Performance Forum 6 01 Jun 2010 08:41 am
